Sponsored by: CARiD
22R Timing with Weber 32/36 question
Old Mar 31, 2012 | 04:12 PM
davecutter's Avatar
First Toyota truck and first post...been reading for a week or so.
New plugs, wires, rotor and cap. Valves adjusted and all cylinders compression between 161 and 171.
Started with stock 8 deg advance and took it for a test drive. Felt weak and lots of flat spots in the power curve.
http://www.racetep.com/webjettune.html
Says "Generally speaking you need a little more advance with a Weber than with the stock carb. A good place to start for most cars with Webers on pump gas is 12-14 Degrees advance at 1000 RPM idle and 36 Degrees total advance by 3000 RPM...This is not cast in stone and you need to make sure your car does not Detonate at these setting. If you get any detonation then you need to back off the timing"
Working my way up to 18 degrees, power gets better and smoother. Stopped advancing at 20 degrees with power still getting stronger.
How far can I (should I) advance? Does the 22R ping (detonate) in an obvious way??
Vacuum advance is to outer diaphragm and off the carburetor port.
Old Apr 12, 2012 | 08:19 AM
davecutter's Avatar
Ok, no takers...settled on 18 deg. advance at idle as best for way I drive. What ignition timing are other 32/36 22r folks using?
Old Apr 17, 2012 | 04:11 PM
92civeg's Avatar
i have a bone stock 87 4x4 22r with a weber 32/36 and i have mine set at 0 degrees (stock) ive tried advancing it to the suggested 15-18 degrees but i starting getting a slight knock and it seemed to run the same as it did at 0 degrees? it has good power throughout the band.... dunno if its related but it does drink some gas i average about 15 mpg with 31's.
id be interested in hearing others timing setup as well
Old May 4, 2016 | 02:08 PM
Xtracab22r's Avatar
^bone stock with a weber? How did you do that, I had to desmog my 22r to use the weber
Old Jun 11, 2016 | 09:17 PM
jmfleming's Avatar
Ignition timing advance need help
Ok I'm coming in a little late s let's hope someone reads this iv got a 1980 20r with a weber 32 36 and my timing is a test 8 btdc iv read that with the weber I should advice the timing up to the 10 to 14 range and a total timing of 28 to 32 the timing plate on my motor only has a 8 and a 0 on it and dose not Have a bunch of degree marks on it so how do I no what range I'm in <br >
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
