Sponsored by: CARiD
2006 Tacoma gear ratio???
Old Mar 15, 2007 | 06:54 AM
discog8s's Avatar
Can anyone tell me what the stock gear ratio is on a 2006 Tacoma, access cab, 2.7 liter 4-banger?
Thanks!!
Old Mar 15, 2007 | 09:09 AM
discog8s's Avatar
Answer:
AFTER RESEARCHING, THIS IS WHAT I CAME UP WITH... ANSWERED MY OWN QUESTION I GUESS. I THOUGHT IT MIGHT BE HELPFUL. THIS IS FOR 05+ TACOMAS
Mechanical/Performance
2.7-liter DOHC EFI
4-cylinder with VVT-i
159 hp @ 5200 rpm
180 lb.-ft. @ 3800 rpm S S NA
4.0-liter DOHC EFI V6 with VVT-i
236 hp @ 5200 rpm
266 lb.-ft. @ 4000 rpm NA A S
4WDemand: part-time 4-wheel drive system with
2-speed electronically controlled transfer case NA S (4x4) NA
Transmission
5-speed manual with overdrive S S (4-cyl.) NA
6-speed manual transmission NA S (V6) S
Clutch start-cancel switch NA S (4x4) NA
4-speed electronically controlled automatic overdrive
transmission with intelligence (ECT-i) A NA NA
5-speed electronically controlled automatic overdrive
transmission with intelligence (ECT-i) NA A (V6) NA
Final axle ratio -- MT 3.31 4.10 (4-cyl.) 3.15
-- AT 3.58 3.73 (V6) NA
Body/Suspension/Chassis
Body construction One-piece frame rails with seven cross members and fully boxed front sub-frame
Front suspension Coil-spring double wishbone suspension
Rear suspension Leaf spring suspension with staggered outboard-mounted gas shock absorbers
Front stabilizer bar (dia., in.) 1.18 1.18 1.18 (0.98 rear)
Steering Variable-assist power rack-and-pinion steering
Steering wheel turns, lock-to-lock 3.43 3.64 3.43
Power-assisted ventilated front disc brakes (dia., in.) 10.83 12.56 10.83
Rear brakes Rear 10-in. drum brakes with tandem booster
4-wheel Anti-lock Brake System (ABS) with Electronic Brake-force Distribution (EBD) and Brake Assist [2] S S S
smthwsn357
May 1, 2024 07:28 AM
polo451
13
Nov 20, 2016 07:49 PM
nick9455649
Sep 11, 2015 05:10 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Poncho0206
Jul 10, 2015 06:21 PM
