Sponsored by: CARiD
1996 with 2001 engine
Old Jul 19, 2018 | 03:22 PM
wyoming9's Avatar
Red face
Your not trying to start this with the Air Intake disconnected ??
Old Jul 19, 2018 | 07:59 PM
Ira Dean McKitrick's Avatar
No codes. No haven't tried with the intake off. Thinking it may be a loose ground. I've checked every fuse and replaced relays. I'll try taking the intake off. Appreciate all the ideas.
Old Jul 21, 2018 | 01:32 AM
wyoming9's Avatar
It will not start with the intake off that is why I asked
You just need to go through circuit by circuit .
Sometimes just swapping parts unless they are tested as failed can make things worse
Old Jul 24, 2018 | 10:56 AM
Still nothing found....will update as I get through all these wires...might be a while.
Old Jul 29, 2018 | 07:08 AM
  #25
Might have found the reason it won't run but not the cause. Injectors lose ground when the engine cranks...anyone have an idea what I've messed up?
Old Jul 29, 2018 | 02:47 PM
  #26
It lives!!!!!! Wiring harness ground was loose! So simple and checked almost every other wire before I got there. Idles a little fast and gonna change some old vacuum lines but it runs like a champ! Thanks all!!!
KZN185W
Aug 12, 2016 10:30 AM
rschmidts
Mar 16, 2015 05:51 AM
ger9147
Engine Swaps
Jan 8, 2012 04:04 PM
ARB1977
9
Dec 5, 2009 09:26 AM
95_4MuddinSr5
Engine Swaps
Sep 19, 2008 07:22 PM
