Sponsored by: CARiD
1993 22re burning oil during start up
Old Oct 28, 2013 | 10:52 PM
Rick541's Avatar
I have a rebuilt 22re in my 1992 pickup. During start up there is blue smoke coming out of the exhaust. This also occurs when you step on the gas. The engine had a full rebuild about 60k ago. It is also leaking oil around the rear seal. I just had the seal replaced about 5k ago. Don't think it could be coming from there, I have no clue how to isolate where the leak is coming from, but it is around the area where the engine meets the transmission. Don't know if this is relevant but when started up the rockers are very noisy and it miss fires until its completely warm. Not sure if it needs a top end rebuild or not.
Old Oct 29, 2013 | 08:10 AM
osv's Avatar
osv
take it to the engine degreaser bay at the car wash, spray the valve cover and block off completely... it'll be messy, you'll get wet.
these motors tend to leak at the back of the valve cover, so i'd clean that area well, and start looking there... it could be dripping down.
bad valve seals can cause oil smoke at startup, but you should probably do a compression check first.
Old Oct 29, 2013 | 03:40 PM
buickid's Avatar
Could need some new valve seals. I would replace the valve seals and set your valve lash. Or just buy a rebuilt head from one of the reputable 22R parts places (engnbldr, etc)
Old Oct 29, 2013 | 03:45 PM
HighLux's Avatar
valve seals. burn oil collected in chamber over time, smoking on startup for a lil bit
valve guides. burn oil while running all the time.
anything burning on the motor would present itself right away. smoke...smell in cab.
I have an extra set of valve seals from a kit...if it ends up being that....shipping and they are yours for free.
Colington
Oct 12, 2015 05:41 PM
Ichneumon
Sep 27, 2015 04:21 PM
puddlepirate
Jun 30, 2015 05:08 PM
bobbybouche
Jun 18, 2015 10:22 AM
Old Red 94
Jun 16, 2015 08:32 PM
