Sponsored by: CARiD
1992 auto to manual swap wiring info needed
Old Mar 21, 2011 | 12:58 PM
1992_4runner's Avatar
hello i just did the swap, still working on the wiring, i was wondering about the break lights,where do i have to wire them at, also the 4wd indicator light does not come on, do i have to wire the light direct
thanks, this is a very informative site
Old Mar 21, 2011 | 01:28 PM
justin_4runner's Avatar
why would u have to wire the brake lights? did u swap harnesses too? i was told that u could do it with out changing to a 5spped ecu...
Old Mar 21, 2011 | 02:27 PM
auto harnness, only one plug would plug in to the manual tranny,
Old Mar 21, 2011 | 02:59 PM
and the wire your talking about is back on the transfer case and i do believe that is for the 4wd.if u look at the way it is wired for the auto in the diagrams i would say that the wire that feed the position switch for the 4wd on the auto number 1 and 3 should go to those wires.
http://www.ncttora.com/fsm/1993/susp...26addcontr.pdf
Old Mar 21, 2011 | 06:21 PM
ok, thank you for the help
Old Jul 31, 2011 | 07:32 PM
Swim's Avatar
Let me know if you can't get your cruise control working, I have a trick
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
ACZR
Jun 23, 2015 07:55 PM
TheManOutside
Jun 18, 2015 03:32 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
