1990 toyota 3.0 4runner water pump replacement
Water pump is bad. Had to replace timing belt a year ago and they didnt replace the water pump. My question is Can I replace the water pump with out removing the crank pulley ? I'm asumming the timing belt is still good.
Water Pump Done !
I replaced the water pump and thermostat. It wasnt to to bad, just time consuming. I also I'm glad I did it myself because the place (KP automotive) that did the timing belt a year ago should have replaced the water pump. They also left a couple of bolts loose and the timing belt tensioner should have been tighter. THEY SUCK ! I didnt have to pull the crank pulley to remove the water pump, which made this job a little easier. Thanks to all the feedback !
Thanks Mike
Thanks Mike
I've tackled enough stuff I've figured out that I like to wrench when I want to & not when I have to lol. the guy I bought this from gave me $$$ off because he said he saw it leaking, but I've put 200 miles on it, and I haven't had any problems. I will probably keep driving it, and see if I can do it myself in a couple months.
voiddweller
19
May 2, 2016 09:10 PM
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
infinityisfive
Jun 16, 2015 06:51 PM
