Sponsored by: CARiD
1989 22re new timing chain 7000 miles died
Old Oct 17, 2015 | 05:50 AM
tomahawkeye's Avatar
new timing chain, timing cover on 1989 truck 22re died while driving around ,a little backfire than engine light turns on. turns over but rotor does not move. work was done by a Toyota mechanic on the side. any ideas on what may have happened ?
Old Oct 17, 2015 | 06:12 AM
bipolarandproud's Avatar
Are you saying the Rotor in the distributor isn't moving ?
Old Oct 17, 2015 | 06:23 AM
yes we pulled the distributor cap and cranked it over rotor did not move
Old Oct 17, 2015 | 06:32 AM
Ok you need to pull the valve cover off or you may be able to pull out the distributor and shine a light and make sure the chain is still on. Your chain may have come off or cam sprocket/gear .There is a roll pin in the dist gear. maybe it failed . Also did yaw replace the timing guides and tensioner too?
Old Oct 17, 2015 | 06:57 AM
yes he replaced everything, pulled head and had it machined. Have thought about distributor gear coming loose
Old Oct 17, 2015 | 01:36 PM
osv's Avatar
osv
i was in a honda civic that broke something in the distributor drive area, the tow bill was over $900, even with aaa long distance coverage :0
i therefore want to always carry a spare distributor for my 22re...
please keep us posted on what the problem was.
Old Oct 17, 2015 | 04:28 PM
Talked to the guy that worked on it and he said would check it out, probably pull the valve cover and see what's up. He's just hard to get to show up and I want my truck back !
junder28
25
Jun 21, 2016 06:24 PM
shisha1999
Sep 21, 2015 08:22 PM
KBar
Aug 3, 2015 05:14 PM
Dakotaneu
Jul 27, 2015 12:03 AM
