Sponsored by: CARiD
1988 3VZE motor part question - STUMPED
Old Feb 6, 2010 | 02:40 PM
tedovt's Avatar
Hello all. Just bought a 1988 4wd pick-up. Runs amazing. My question is this:
What part sits directly to the left of the cold start injector? It has 3 nipples that connect to vacuum hoses. I just replaced my cold start sensor, and I accidentally broke a nipple off of that part, and I am having an air leak.
I could not find a part number, or a name for it. Searched everywhere on line, and the Haynes book doesn't list the part. I believe the nipple that broke off goes to my AS hose.
I know these engines run great, however they also have a pretty complex vacuum system. What part do I need to replace?
Thanks in advance,
Ted
Old Feb 6, 2010 | 04:50 PM
tedovt's Avatar
this part circled.
Old Feb 6, 2010 | 05:19 PM
DeathCougar's Avatar
Its basically just a splitter for the vacuum. Since there is only one port in the intake, this splitter allows for 3 vacuum lines to rin off it, without hving 3 different holes drilled in the intake.
It needs to be replaced, since you still need full vacuum to each line.
Old Feb 6, 2010 | 06:09 PM
tedovt's Avatar
Thanks for the quick reply. However I am still not able to find the part, or part number to replace. You would thing google would be our friend. I tried searching "intake vacuum splitter, vacuum splitter, intake splitter", and nothing.
Old Feb 6, 2010 | 08:52 PM
Tracey98277's Avatar
you should post in "items wanted" or PM someone who is parting out a motor, or go to the local salvage yard.
zd92655
Mar 6, 2022 12:58 PM
JF9243176
Oct 8, 2017 04:21 AM
Vargntucson
Jul 4, 2015 12:15 PM
JF9243176
Jun 24, 2015 04:53 AM
