Sponsored by: CARiD
1987 Toyota stalls
Old Oct 6, 2009 | 02:22 PM
1lowyota.'s Avatar
why whats wrong that's causing the problems its been running better but still runs rough when idling and still stalls a few times here and there
Old Oct 6, 2009 | 02:43 PM
master tech1's Avatar
have u even rebuilt the carb yet, u need to, then check timing after the rebuild, also check vaccum, it sounds like ur accelator pump is bad
Old Oct 7, 2009 | 08:04 PM
1lowyota.'s Avatar
i have only changed the fuel pump and filter also air filter and changed the oil in it sence i bought it i haven't rebuilt the carb because i have no clue how to and it looks like alot of work just to take it off
Old Oct 7, 2009 | 10:21 PM
RMP8080's Avatar
you still maybe have rust in the fuel tanks, check the fuel filter again.
I had same problem, removed the tanks drained and cleaned out. It had a lot of rust inside and the filter was getting jammed up with rust flakes.
the fuel tank has a drain plug.
bigjstang
Jun 2, 2025 03:56 PM
Charecter1
Nov 6, 2023 10:08 AM
MO transplant
Apr 23, 2023 11:58 AM
shar
Jul 9, 2015 12:38 PM
Jnkml
Jul 6, 2015 01:20 PM
