Sponsored by: CARiD
1987 sr5 22R carb 4X4 she is tired
Old Nov 23, 2009 | 08:55 AM
2003mikem's Avatar
1987 sr5 22R carb 4X4 she is tired can barely get up to 75 on the high way.
I have a 1992 2 wd with a 22REC can they be swapped out ?
I would like to keep it carbureted? I guess I am asking will they bolt up and if so what do I need ahead of time ?
Old Nov 26, 2009 | 08:19 PM
brian2sun's Avatar
Why do you want to keep it carbureted if you want more power? The EFI will add significant hp. The '92 can work, but I would guess you'll probably need the '92's ECU.
Old Nov 30, 2009 | 04:30 AM
2003mikem's Avatar
Ok here is what I found
The compression is 165-170 on all cylinders.
Timing is spot on.
Plugs wires cap rotor are all new.
Truck runs great, but I can’t get it above 70. Unless going down a incline.
I am thinking it is the 30.5” tires? Will this make that much of a difference over the stock tires?
Old Nov 30, 2009 | 05:05 AM
19RUNNER86's Avatar
not really. i had an 87 that would do about 60-65 on a highway. uphill... forget it. the carbs just arent powerhouses. especially 4wd...
Old Dec 4, 2009 | 04:08 AM
2003mikem's Avatar
I have a 92 2wd complete truck.
So I can swap the engine and the harness and be good to go?
MO transplant
Apr 23, 2023 11:58 AM
BushPig
Oct 29, 2022 06:26 AM
Yota.Jay
Jul 23, 2015 08:08 PM
87blyota
Jul 10, 2015 04:31 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
