Sponsored by: CARiD
1986 Pickup interior fuse box removal?
Old Nov 16, 2010 | 03:29 PM
tontozerbino's Avatar
Hello all-
My first thread is hopefully an easy one. I've searched and searched for some info on this with no luck. I've looked in some FSM's and couldn't find my answer there, either; I do not have a Chilton or Haynes.
I have a 1986 2wd pickup. I'm trying to get access to some wires and can't figure out how to remove the fuse box/panel behind the driver's side kick/dash panel. The fuse (and relay?) box is a white plastic box with one bolt at the bottom. But it feels held in place on at least one point at the top- I can't see what's holding it and am afraid to use too much force for fear of breaking a tab or screw mount.
Any help would be greatly appreciated,
Thanks
Old Nov 23, 2010 | 12:41 AM
duck tape's Avatar
Btdt
just went through the same situation on my '92
removed fender and wiring harness through body
use long prybar through hole to pry off
Old Nov 23, 2010 | 04:59 PM
wow, really? What was keeping the fuse box attached?
Old Nov 23, 2010 | 05:04 PM
xxxtreme22r's Avatar
why is there two threads by you asking the same thing?
Old Nov 23, 2010 | 10:51 PM
duck tape's Avatar
looks like almost nothing
refer to the pictures
the tab? above the ground wire and bolt
this is the backside of the fusebox
the white plastic with blue dot is your enemy, pry against it
mounting tab? behind ground wire
hole to go through
Old Dec 2, 2012 | 11:42 AM
Yota_guy's Avatar
Hey!! I have a leak behind my kick box fuse panel and I'm having the same problems. Does any body have pictures that could help me with the removal of my fuse panel!
Old Feb 27, 2018 | 01:47 PM
himskim's Avatar
Were you ever able to figure this out? I am having the same problem. Thanks for the help.
Old Feb 27, 2018 | 08:35 PM
RAD4Runner's Avatar
Remove bolt on bottom, Look (IIRC) above and behind the fuse block, find a latch that you press one way so you can slide the whole fuse block up / down.
5280jo
10
Jul 13, 2015 10:05 PM
GorgeRunner
Jun 27, 2015 07:01 AM
Corey
Jun 25, 2002 08:39 PM
Corey
Jun 25, 2002 11:13 AM
