Sponsored by: CARiD
1985 toyota pickup 22RE auto 2 w/d
Old Oct 6, 2011 | 10:33 AM
confussed's Avatar
will spin over but will not crank. I have put 2 fuelpumps pressure regulator, iginiter, distrubutor, throttle body sensor, ECU unit, coil, fuel filter, I have checked all fuse's was running that morning tryed to put a sterio in it and now stoped running. And i do have spark I can spray stating fluid in the thottel body and it runs i'v checked the main relay the open curcuit relay HELP LOL
Old Oct 6, 2011 | 10:56 AM
Sensei's Avatar
Do you have fuel pressure ? Sounds like when you installed the stereo you tapped into a circuit (+) that maybe you shouldn't have. Retrace your steps on your stereo install and find where you compromised a circuit.
Old Oct 6, 2011 | 12:21 PM
confussed's Avatar
the olny reason i dont have fuel pressure i have a gas leak in the line now but the pump is good
Old Oct 15, 2012 | 04:07 PM
confussed's Avatar
carb. problem it will idle but as soon as i give it some gas it starts fluttering the ele. choke is not hook up could that be a problem or no
6th Gear
19
Dec 10, 2019 07:31 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
Eagle564
Jun 23, 2015 11:29 PM
JaredL
Jun 16, 2015 04:47 PM
