Sponsored by: CARiD
1 inch body lift questions
Old Apr 11, 2008 | 07:25 AM
4Crawler's Avatar
Originally Posted by mkgarrison5
dang all of this seems like a more trouble than its worth (talking about the 1 inch lift period) seems like it would be easy for me just to cut out some of the wheel well guards to keep from rubbing a full flex.. the reason why i wanted the lift is bc on my 02 taco it has 245/75/16 tires and i want 265/75/16's and from what i read it will rub at full flex when the wheel is turned. any other ideas perhaps?
Well, one option is to put on the tires. If they rub, start trimming. If they still rub and you can't (or don't want to) trim any more, then do the body lift. Not a lot of work on a 1" lift, maybe 3-4 hours install time, aside from adjusting the A/T shift linkage and installing the steering shaft extension, not a lot of things to deal with.
Old Apr 11, 2008 | 08:31 AM
mkgarrison5's Avatar
10-4, i think thats what i am gonna do! atleast ill have this to check back to, also other people using the search can look this up with easy aside from all of the BS you have to sift thru when using the search button..thanks again guys for your time!
Old Apr 13, 2008 | 02:56 PM
dbcx's Avatar
I did mine in about 1,.5 hours including raising the bumper and installing the steering spacer. I used about a foot or so 2x4 and found the middle and raised one side at the time, i also had to loosen the other side for some movement. It is really simple.
Old Apr 18, 2008 | 08:34 AM
Greyhorn's Avatar
I did a 1" 4crawler on my FJ60 and it was pretty simple. I had to modify the fan shroud a bit but nothing major. Putting one on my Runner soon. I believe with a 1" you may get away without modifying the auto shifter, but if needed there is some adjustment room. I have an auto as well.
Old Apr 23, 2008 | 01:24 AM
  #25
oblitter8's Avatar
I just put on 2" body lift. took me about 2 hours and cost me in total almost $25. 2" square steel ,1/8" thick, 3" long with a hole in the middle, x10 and some new bolts. Better then a bought one...
Old Apr 23, 2008 | 05:26 AM
  #26
waskillywabbit's Avatar
For those that find this thread later the above description is a perfect example of how NOT to do a body lift!
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
akaphilly
Jul 9, 2015 02:18 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
