High Temp. Line Pressure Up (VSV)
I cannot find this part anywhere, apparently its discontinued from Toyota.
I need the VSV for the 'High Temp. Line Pressure Up System' for an 88 22RE
Part No. 90910-12066
(its the blue VSV on the top of the valve cover)
Thanks!
Thanks!
in case you can't find one: http://www.toyotapart.com/90910-12066.html
I have a valve cover with 3 VSVs on it, here is the blue one:
The number on it is 90910-12085 (OEM Toyota VALVE, VACUUM SWITCH according to toyotapartzone), which is not the number you posted. I'll have to look at the other 2 and see if they match your number.
