3.4 Parts!
3.4 Parts!
I need the following to complete my 3.4 swap, i'd like to get parts from a 1998 4x4 4Runner but that may not be necessary for everything.
Power Steering Pump Got it!
Alternator Got it!
ECU 1998 4x4 5 speed (not sure if it has to be 4Runner or not)
Intake System (Cold Air)
AFM (1998) Got it!
Flywheel
Starter Got it!
TPS Got it!
Clutch
Throwout Bearing Got it!
Pilot Bearing
Pressure Plate
Exhaust
Headers (aftermarket)
3.4 Wiring Harness (1998 4x4 manual 4Runner)
Shoot me a PM on here if you have anything i need.
-Brian
Alternator Got it!
AFM (1998) Got it!
Flywheel
Starter Got it!
TPS Got it!
Clutch
Pilot Bearing
Pressure Plate
Exhaust
-Brian
3.4 parts
I have a power steering pump, flywheel, brand new throwout Bearing,
manual ecu and harness out of a 1997 t100. $450 to your door for every thing.
Brian, I am going up to the junk yard today, gonna look for an AFM and TPS for ya.
Just to clarify these are the ones you need?
Toyota Part 22250-20020 OEM Toyota METER ASSY, INTAKE A
Toyota Part 89452-35020 OEM Toyota SENSOR, THROTTLE POS
Double check and call me ASAP, check your PM.
Gave you a call, those are the right numbers.
Here is a solid tip . The clutch disc is not marked "flywheel side" as most This is because the same disc is used on 3RZ. On 3RZ the spring side goes towards the pressure plate, on 5VZ the spring side goes towards the flywheel. That mixup would cause you a lot of down time redoing the clutch. Like the seatbelt add says...You can learn a lot from a dummy!
I have to say I saw that in LCE 's catolog. I was doing a clutch in a Taco and didn't pay attention on dissassebly thinking it would be marked on the new disc. It wasn't ...then I saw that in the catolog..bottom left hand cornor in the clutch section if you have the catolog.
That's a pretty helpful piece of info!
Well they are pretty helpful people I think The owner is very smart. I have been done there about 9 times selling them cores. I love it and they love playing with my dog.,I get to see the set up and talk to them. I'm even sending the General Manager a set of my hubs this week (IFS) and a 20 R head I found for them .Heading to the junkyard to look for some of your stuff, later
XtraCab
Apr 12, 2020 05:25 AM
mengquis
Jul 13, 2015 10:39 AM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
Jul 12, 2015 07:15 PM
