Transmission Clunk, 07 Tacoma
Old Oct 18, 2007 | 08:36 AM
ryland's Avatar
This has happened twice over a two week period.
Engine cold, sitting for 24 hours.
Start up, put in drive, take the brake off and it won't go. Feels like the brake is still on.
Give it some gas and WHAM! A loud clank and it goes into gear and drives perfectly.
The second time it happened rather than give it gas I put it into neutral and then back into drive and this solved the problem.
Any ideas??
2007 Toyota Tacoma, Double Cab, 4X4, Auto, Long Bed, Shell, 8000 miles
Old Nov 16, 2007 | 05:49 AM
AppleJack's Avatar
Take it to the dealer. Is it still under warranty?
Old Nov 16, 2007 | 07:45 AM
Joe's Toy's Avatar
Warrantys are our friends! I make a point to bring my truck to the over priced dealers every time I find an issue that might need addressing.
Old Nov 16, 2007 | 08:09 AM
dropzone's Avatar
Fossilized
Yep, he has got 28K worth left (I think drivetrain is 60k so 52k) Take it to the dealer, though it almost sounds like your parking brake is sticking...
Not sure but there may have been a TSB on it;
Go here http://www.empirepao.com/
on the left side of webpage look at tech and click on TSBs (stupid direct linky won't work for some reason)
Dealership should be able to take care of you, and if they don't tell them you want to talk to regional guy....Toyota in some cases seem to be less than cooperative in some cases on the latest generation of Tacos
Old Nov 16, 2007 | 09:38 AM
ryland's Avatar
havent found a tsb. i did tell the technician about it when i brought it in for alignemnt. as i suspected there isnt much they can do if they cannot reproduce the problem. i also spoke with my mechanic who thought it could be a brake issue. i still have to bring it back for more alignment crap so i may ask for a brake inspection and a transmission inspection while it is there. thanks for the replies.
Old Nov 16, 2007 | 09:45 AM
ryland's Avatar
by the way thankyou for that link to the tsb's, that is a great resource!!
Old Nov 22, 2007 | 05:34 AM
ohioyotaguy's Avatar
sorry to ask a question off topic on someone else's thread, but I need to know.. ocdropzone, you have 285's on your 05... do you have a lift? I want to run 285/75R16's on my 06 TRD DC 4x4 but was told they would rub bad. Thanks.
smthwsn357
May 1, 2024 07:28 AM
maachine
Aug 6, 2015 02:23 PM
gillesdetrail
Aug 3, 2015 04:43 PM
ripp96
Jul 25, 2015 02:32 PM
Poncho0206
Jul 10, 2015 06:21 PM
