Leaky 3rd/Axle housing
Old Jul 26, 2008 | 01:14 PM
24Runna's Avatar
So The idiots that replaced that gasket 30k ago won't cover replacing the gasket again, even though its leaking, AGAIN.
I honestly have never heard of this problem with the 4th gens.
So I was like fine, I'll do it my self.
Got everything together, draining the rear, and started to undo the nuts.
And then I see the delightful sight of a broken stud. I hardly put ANY force on it and it spun.
The fu#$#$ over-torqued it. How would I go about and replace these studs?
I am Not happy with Pauly Toyota right now....
TIA.
Old Jul 26, 2008 | 01:17 PM
jason191918's Avatar
What do you mean it spun? Did you break it off or did it just unscrew?
Old Jul 26, 2008 | 01:31 PM
24Runna's Avatar
Like the nut stay put with the stud, and then they both sin together.
I REALLy need help guys as this a DD, and Pauly Toyota is of no help.
bigt's Avatar
yeah if you cant get 2 bolts on it to get it out i used a very small pipe wrench if there is enough room.. if not vice grips heat and thrust!
im just putting my 3rd in for the 3rd time with rtv this time because i forgot it last time DOH!
Old Jul 26, 2008 | 01:40 PM
24Runna's Avatar
I think that is what they forgot, the RTV. They guy at the parts counter said to use RTV to make sure it doesn't leak and I was like already got it covered, but 4 years ago one of your techs didn't.
Old Jul 26, 2008 | 06:28 PM
24Runna's Avatar
Okay, so it turned out that the studs are screwed in, big relief. Now I'm stuck at getting the third off.
Old Jul 26, 2008 | 06:29 PM
bigt's Avatar
did you pull the axles out??? they need to go quite far before you can slid the 3rd out..
Old Jul 27, 2008 | 12:19 AM
24Runna's Avatar
Well Ive spent a good amount of time figuring that out, lol. I didn't want to pull it all the way out cuz I didn't want to deal with bleeding the brakes. But now I have to.
Now all that's left to do is put RTV on the gasket (anything special to it?), and put everything back together.
Before I closed up shop, I decided it would be to my advantage if I organized everything, so I organized all the bolts and nuts and washer and sockets and wrenches relating to this. Much better now, before I was having a hard time doing anything, now that I can find everything and nothing is in my way, its all good.
As far as putting all back together, anything special? I should take into account when putting the rear back together?
And why didn't anyone ever tell me the 3rd member weighs 3,000#? lol, I nearly smashed my finger, but it's gonna be a bitch getting it back up.
Thanks for your help guys, it is definitely appreciated.
(Sorry if there is grammatical errors and such, its 3:30 here and I have a killer headache, so its off to the shower and then bed for me.)
Old Jul 27, 2008 | 10:41 AM
24Runna's Avatar
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
