Icon Shock Rebuild
Old Apr 18, 2016 | 01:55 PM
MSR's Avatar
MSR
Icon Shock Rebuild
I thought I would show some of the internals on a ifp icon coil over. Here is how we received them from another shop.
Old Apr 18, 2016 | 02:02 PM
MSR's Avatar
MSR
Then we removed the spring seat with a spring compressor.
Old Apr 18, 2016 | 02:05 PM
MSR's Avatar
MSR
After releasing the nitrogen charge we started the dissasembly
Old Apr 18, 2016 | 02:10 PM
MSR's Avatar
MSR
then removed the shock stem and piston assembly while being careful not to get old shock oil everywhere.
Old Apr 18, 2016 | 02:13 PM
MSR's Avatar
MSR
loosen the nut at the end of the shaft and carefully take the piston and valves off keeping them in order as to not change the shock valving.
Old Apr 18, 2016 | 02:15 PM
MSR's Avatar
MSR
here is the shock components all tore apart.
Old Apr 18, 2016 | 02:16 PM
MSR's Avatar
MSR
some new fk bearings com10t to be specific
Old Apr 18, 2016 | 02:18 PM
MSR's Avatar
MSR
Here is the important part
Old Apr 18, 2016 | 02:22 PM
MSR's Avatar
MSR
The rebuild kits Icon sells cover most of the shocks they put out by using just one kit. So you will have one seal you do not use. In this case you can see the old seals to the left. A black dust seal and then the disogrin oil seal. In the package you can see the yellow seal that does not get used with this shock. So in this case it is ok to have parts left over.
Old Apr 18, 2016 | 02:25 PM
MSR's Avatar
MSR
Reassemble with new oil and a 250 psi nitrogen charge and ship back to the consumer. If you have any questions post them up.
Old Apr 18, 2016 | 06:34 PM
vital22re's Avatar
totally a bro
what is the most common failure you see on these units? how many miles do you expect the rebuild to last.
Old Apr 19, 2016 | 06:46 AM
MSR's Avatar
MSR
The spherical bearings are always the first problem but depending on how often you clean your shock a scored shaft will take out the seals quickly. I would expect these to be good for another 30,000 miles of abuse. Most of my customers from that area get about three years of trouble free use.
Old Aug 23, 2017 | 08:09 AM
danthemanx07's Avatar
This thread is a little old, but I have a couple of questions. Must the charge port be replaced with each rebuild? ICON's rebuild kit comes with a new charge port, but I have found other kits with the seals only. And is there any substitute for ICON's oil? It is pricey, and there is no where local to me that carries it.
Old Aug 23, 2017 | 05:11 PM
MSR's Avatar
MSR
No the charge ports can be reused. Icon will always suggest their fluid however you could use any 5 wt suspension oil. JM92 would be a close match.
Old Aug 23, 2017 | 06:41 PM
Thanks for the info. I'll look into the JM92. I have a line on some used Icons, but they are going to require a rebuild. It doesn't look like I would be getting in over my head based on your pictures. Thanks a bunch.
Old Sep 8, 2017 | 05:04 PM
Well I didn't think I was getting in over my head, but I can't get the lower spherical bearings out. They are in bad shape and don't seem to want to move. Any tips on applying some force without breaking anything?
Old Sep 11, 2017 | 07:08 AM
MSR's Avatar
MSR
Did you remove the retaining clips? Otherwise we use a press to get them out. If need be you can add some heat to expand the aluminum.
Old Sep 11, 2017 | 07:22 AM
Clips removed. I used a vice with a wood block on one side and a socket on the other. No go. I thought that should have been sufficient, but I guess not. Was crushing the wood but not moving the bearing. Have used a little heat as well. I was hesitant to use a press for fear of mangling the aluminum rod end. How do you avoid this?
Old Sep 11, 2017 | 07:41 AM
MSR's Avatar
MSR
You can use a socket or bearing race. You can always wrap the socket with tape to keep from scratching the rod end.
Old Sep 11, 2017 | 07:52 AM
Yes. I was more concerned with leaving impressions in the aluminum rod end. I can't believe that it hasn't come out yet, so I am anticipating some damage using steel on aluminum if I use a press. Sounds like it is unavoidable though.
Dharris1986
Oct 13, 2021 08:25 PM
SBeckner80
May 24, 2016 05:12 PM
Murfy101
Apr 18, 2016 10:57 AM
Daniel Castaneda
Mar 29, 2016 11:22 AM
rhale
Feb 5, 2016 08:38 AM
