help me understand this 4th gen "multi mode 4wd" crap
Old Mar 1, 2005 | 10:04 AM
jacksonpt's Avatar
Senior Member
OK... we've had my wife's 4th gen 4Runner for about a month now, and we got our first real snow storm last night. All these new fangled switches, dials, and idiot lights have me confused.
What ever happened to good old manual locking hubs? Or at least a mechanical shifter for a true transfer case?
Oh, that's right... the soccer mom revolution...
OK, anyways... how about shedding some light on this multi-mode 4wd business for me? I went to put it in 4wd last night but there are like 3 settings that all seem to be 4wd, and different lights flash for each setting.
so...
2hi and center diff unlocked - traditional rear wheel drive?
2hi and center diff locked - ???
4hi and center diff unlocked - ???
4hi and center diff locked - traditional 4wd?
4lo and center diff unlocked - is this even possible??
4lo and center diff locked - traditional 4lo?
The manual is about worthless... I assume flashing lights mean that the whatever (transfer case, diff, whatever) isn't engaged/locked yet?
It's an 04 if it matters.
*sigh* I miss manual hubs...
Old Mar 1, 2005 | 10:18 AM
potsy's Avatar
From: Ocean Beach, CA Five square miles surrounded by reality.
i can offer this much...
2 hi=rear wheel drive
4 hi with center dif unlocked=all wheel drive, safe for dry pavement.
4 hi with center dif locked=traditional 4 wheel drive
as far as 4 low goes...i dont know why you'd need 4lo with the center dif unlocked.
with the center dif locked it basically transfers 50% of the power to the front dif and 50% to the rear dif. with it unlocked (i think) it basically acts like an open dif, transfers the power to the front or rear difs based on which needs more power (someone correct me if i'm wrong about this).
i usually use 4 hi with the center dif unlocked for snow/ ice/ heavy rain when i'm on road, and use 4 hi with the center dif locked for dirt/ mud off road.
edit: in 2 hi the center dif doesnt do anything. if you try to lock it it will just flash the warning light, but it doesnt really change anything.
Old Mar 1, 2005 | 10:23 AM
jacksonpt's Avatar
Senior Member
as in, rear wheel drive until the wheels slip, then the fronts kick in? That's pretty much worthless, in some ways it's even dangerous where I live. I want true, traditional 4wd, with all 4 wheels pulling all the time.
Old Mar 1, 2005 | 10:32 AM
X-AWDriver's Avatar
AWD is better in slippery conditions anyday over 4wd since true 4wd doesn't stop spinning until you let off the throttle. I drove my AWD Eclipse around for 7 mountain winters and definetly has a more secure feeling than my Runner does but anything over 8 inches of snow then it had problems.
Old Mar 1, 2005 | 10:35 AM
hillbilly's Avatar
No, the front diff is fully engaged when in 4Hi/4Lo, but the front tires are able to rotate at a different rate than the rear when needed (which is similar to AWD systems). Locking the Center Diff (T-case) synchronizes the front and rear axles and is not intended for typical paved surfaces.
You'll need a locker on each axle to get all four pulling all the time...
Old Mar 1, 2005 | 10:37 AM
jacksonpt's Avatar
Senior Member
I've never liked AWD because I never know how it is going to respond if/when things get slippery. And a lot of AWDs feel like they cut power (perhaps that's other traction control systems, but whatever). My 4Runner goes anywhere, and I know exactly how it's going to respond - no lurching, no sudden power loss, no clunking.
But perhaps I don't have enough experience with good AWD systems... I just know I hate driving my wife's BMW in the winter for that reason.
Old Mar 1, 2005 | 10:39 AM
jacksonpt's Avatar
Senior Member
ok... I get it now - thanks all.
Old Mar 1, 2005 | 10:59 AM
switchback's Avatar
Drive a Subaru (any model) in the snow one time and you will change your mind about AWD for sure. There is a saying here in Colorado. . . "If its stuck in the snow, it ain't a Subaru". I drove one for years and loved it. If I ever buy another "car" it will be another Subaru. I just always wanted a truck, because I couldn't go to many off road places in my Outback.
As far as 4Hi with the diff. unlocked, it will be a bit like an AWD with the exception that it doesn't have a computer monitoring the slipage of each individual wheel like a good Full-Time AWD system does. Still better for the snow than a traditional 4WD though. Hope this helps!
Old Mar 1, 2005 | 11:32 AM
rimpainter.com's Avatar
Roger that. My parents had one in Seattle, and that thing would not get stuck when it snowed. We purposely went out in snow storms and tried to get it stuck; up hills, off-camber, etc...but it always pulled through.
If I ever move anywhere that gets snow, a Subaru will most likely be in our garage (hopefully a WRX)
Old Mar 1, 2005 | 12:04 PM
X-AWDriver's Avatar
Yes,some of the newer AWD systems incorporate too much computer control but the system used in the 1st and 2nd gen DSMs worked very nicely and allowed you to make the power input and steering but never allowed the rear end come. Subaru and Mitsubishi have a few new goodies on their newer systems but they still allow alot of driver feel and control.
I used to take a backway through a state park close to my house every time we got 4-10" of snow just to play in my Eclipse since there's nothing like "drifting" through a whole corner with the rear kicked out and the front tires still controlling the nose.
Old Mar 1, 2005 | 12:46 PM
switchback's Avatar
Yeah, Those WRX's are sweet! It's no wonder Subaru's are almost always in the top 3 in the World Rally events.
Old Mar 1, 2005 | 12:52 PM
potsy's Avatar
yeah, i used to own a subaru myself, the thing was awesome in the snow...thats alot of the reason i got a 4runner instead of a tacoma...the availablity of the awd function of the 4wd system. as far as i know only the 4runner and jeep grand cherokee have full-time 4wd (awd).
Old Mar 1, 2005 | 12:53 PM
smiljko's Avatar
When I had Lada Niva I used it all the time.It's quite good for towing on the road and uphill
Old Mar 1, 2005 | 12:56 PM
potsy's Avatar
i guess i never figured i'd need 4lo on pavement...but then again, i never really tow anything...makes sense, though.
foampile
Dec 18, 2022 01:29 PM
greasyglue
Dec 12, 2015 12:57 PM
nick9455649
Sep 11, 2015 05:10 PM
ManzDaKlown24
Aug 22, 2015 10:25 PM
