Differential Drop
Old Nov 12, 2006 | 07:06 PM
Net4N6's Avatar
Differential Drop
I had a 3" Cornfed spacers on my 06 4x4 4runner. I read on the forum regarding differential drop. As I understand, the spacer lower the differential. Installation is another story. Do I need to install the diff drop?
What is the long term effect on my 4runner if I don't install the drop?
Thanks advance for your advice
Old Nov 12, 2006 | 07:32 PM
tc's Avatar
tc
Search - this is one of the most discussed topics it seems,and both sides get pretty "emotional" about it...
The reason is to make the CV angles shallower. Whether you need to or not is a matter for debate.
It decreases your ground clearance (from lifted, but without diff drop). Whether that's significant or not is a matter for debate.
Old Nov 12, 2006 | 07:33 PM
Good Times's Avatar
you don't need it.
Old Nov 13, 2006 | 08:50 AM
Net4N6's Avatar
Thank you so much. I can sleep better now. I plan to keep my 4runner for a long time and I don't want to worry about it.
Old Nov 13, 2006 | 09:55 AM
4Crawler's Avatar
If you noticed decreased CV boot or joint life, then you might want to lower the diff a bit, but if not, it should be fine as long as you don't see any binding in the CVs at full droop.
justdifferentials
14
Jun 11, 2017 08:36 PM
djpg2000
Sep 7, 2015 10:36 AM
Jwp1
Sep 6, 2015 11:03 AM
justdifferentials
Sep 5, 2015 06:52 PM
