Cyclone pre-filter install in V6 '05 4Runner
Old 02-06-2008, 07:42 PM
Teotwaki's Avatar
Wahooo! A package on the porch today!
Brand shiny new cyclone pre-filter from 2008 FJ Cruiser 17730-31030
Spinner
Out with the old using 12mm on the bolts and 10mm on the clamp
Side by side
"Scoop" on the old inlet fixture
Water drain holes on the old fixture
Big hole in there
nice fit into fenderwell
Shiny new Pre-filter
A big THANK YOU to Robert and Scott at Findlay Toyota of Las Vegas!!
Old 02-07-2008, 10:46 AM
Teotwaki's Avatar
This is the air inlet scoop that is used inside the FJ's fenderwell. I am looking for a used/free one.
Old 02-08-2008, 06:50 AM
TheBlueWave's Avatar
How much did this upgrade cost and what are the benefits?
Old 02-08-2008, 01:41 PM
Teotwaki's Avatar
List price is $132 IIRC...... I got it to my door here in SoCal for $100
The spinner blades knock the dirt down into the squeeze blub, a more straight-thru tube and no open water drain holes.
Here is another guy's pix of the dirt his managed to collect on his Aussie Prado
That means less of it clogging the air filter
Old 02-11-2008, 06:28 AM
tempsho's Avatar
Thats a pretty slick little unit. Do they make the same thing for the 4.7?
Old 02-11-2008, 06:32 AM
Teotwaki's Avatar
Pretty sure that they do not because of the air intake filter arrangement.
Old 02-13-2008, 06:36 AM
Ok, cool. I thought you would respond with some Turbonator message like "cyclonic action to the intake air stream increases horsepower by up to 35%" or some crap like that. Guess I should know better that Yotatech members are smarter than that (except for me, lol).
Old 02-13-2008, 10:02 AM
Teotwaki's Avatar
I was actually asked if I noticed any difference in the sound of the exhaust...
PS: If you look at the horsepower numbers for the FJ and 4Runner (V6) the FJ only looks higher because the number includes running on premium while the 4Runner was running on regular. Otherwise the FJ loses no horsepower due to the insertion of the pre-filter so my 4Runner won't lose any ponies either
Old 02-16-2008, 05:10 PM
Teotwaki's Avatar
When I was getting ready to add a scoop to the inlet I pulled the dust drain-nipple-thingy and discovered just how much street dust the prefilter had grabbed in 3 or 4 days of use
The FJ Cruiser inlet scoop is not going in. It is a huge headache to pull the inner fenderwell skirt and halfway thru I gave up and put it back.
I bought a PVC "street elbow" with a flange on one end which I shortened up and I modified the inlet area too
On the pre-filter I cut its rubber inlet flange back about an inch leaving a little ridge to ensure a tight fit. I used a silicone type sealent to glue it together
I added a new strip of rubber sponge weather stripping and plugged the whole thing back into the fenderwell.
The inlet is angled slightly upward which gives me roughly 40-41 inches above the ground for water fording
G-off
12-29-2015 12:44 PM
dzldust
7
10-06-2015 05:39 AM
anniesball
09-07-2015 11:20 AM
zz_denis
09-06-2015 03:43 PM
seab1209
09-03-2015 05:41 PM
Quick Reply: Cyclone pre-filter install in V6 '05 4Runner
