Cornfed 4th Gen lifts
Old Jan 21, 2006 | 10:40 AM
cervesa33's Avatar
I know there are a few 4th Gen 4Runners on the eastcoast that are running the Cornfed lift. I would like to see some pics and hear your likes or dislikes of them.
Thanks in advance
Old Jan 22, 2006 | 03:32 PM
spyne's Avatar
There are several write-ups over at t4r.org. Most of the members over there are not as off-road focused as those on this forum. However, the ones with the lifts, for the most part, seem to use them
Old Jan 24, 2006 | 11:40 AM
BlkSS1755's Avatar
3" Cornfed. LOVE it .. should have done it sooner!
Old Jan 25, 2006 | 03:18 PM
AlexJet's Avatar
I have one. So far I like it. And I do take my truck off-road often. This was one of the best mods I've done. Right now I'm not worrying about rocks and mudholes on trails.
Old Jan 26, 2006 | 05:13 AM
cervesa33's Avatar
Thanks for your replies
I have talked with the Portsmouth shop and I will probably have them install it this spring. I would like to run BFG 285/70R17 A/T's (32.8") but I am not sure if they will rub or not while offroad.
Old Jan 26, 2006 | 02:42 PM
AlexJet's Avatar
285/70 R17 will be rubbing. Even 275/70 will have some. You'll have to cut-off some plastic and do some metal work if you will mount them on stock rims, or only plastic if you'll go with 17x8 with 4-1/2 backspacing aftermarket ones.
Old Jan 26, 2006 | 08:32 PM
Expat's Avatar
You will fit the 275's without rubbing on stock 17" wheels - or in the worst case you might touch the plastic wind deflector when reversing on full lock but no need to cut anything.
I have a 2.5 Daystar spacer lift and 275's and I wheel pretty aggressively for a basically stock 04 Runner.
For what it's worth I will probably try 285's next but am prepared for some minor trimming with new wheels.
nick9455649
Sep 11, 2015 05:10 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Backcountry411
Jul 24, 2015 08:06 AM
