Buying 4th Gen....question
Old Jan 3, 2008 | 12:01 PM
mntbikr15's Avatar
Hi
Buying a 4th Gen possibly as soon as tomorrow.
Question is regarding the difference between the SR5 model and the Sport model. I like the way the sport drives better, and like the look of the hood scoop (although I'm under the impression its mostly cosmetic ?).
I am going to be putting a lift on it, most likely an OME 3 inch. Now knowing totally what this entails I dont know if there would still be any benefit to the sport edition after the lift.
Thoughts?
Thanks,
Evan
Old Jan 3, 2008 | 12:39 PM
TheBlueWave's Avatar
The hood scoop is entirely cosmetic.
The Sport rides better because it has the X-REAS suspension system. Its a hydraulic balancing system designed to reduce body roll and improve ride charactoristics. When you lift the suspension, you might have to remove the X-REAS system entirely, unless you don't lift it much. I'm not sure how a 3" lift affects this, as I own an SR5.
Old Jan 13, 2008 | 10:29 AM
Colemanfu's Avatar
Did you get one yet?
Old Jan 16, 2008 | 05:41 AM
LEADfoot's Avatar
xreas is removed completley with OME
OME rides better then xreas
Old Jan 18, 2008 | 09:54 PM
MLB's Avatar
MLB
You still get the bigger front brakes.
Old Jan 21, 2008 | 11:18 AM
ssmathis's Avatar
Sport model also comes with painted and heated side mirrors. Depending on where you live, the heated part is nice to have.
Old Jan 21, 2008 | 08:17 PM
MLB's Avatar
MLB
Is there a switch for the heating? I just got my 07 and haven't seen anything in my limited searching. The manual is THICK!
Old Jan 22, 2008 | 05:39 AM
ssmathis's Avatar
No switch. They come on when you turn on the rear defroster.
Old Jan 22, 2008 | 06:06 AM
Chrisnxl185's Avatar
V8?? if your getting a 4th gen you better be getting a V8. I love the acceleration my dads V8 sr5 has
RobotMoose
Feb 22, 2020 07:44 AM
Obmi
Sep 10, 2016 04:40 AM
pickle6415
Oct 19, 2015 08:08 AM
jdt79
Sep 16, 2015 02:14 PM
mordell
Sep 12, 2015 10:13 AM
