2UZ Timing Belt Help
Old Nov 14, 2011 | 02:55 PM
fierohink's Avatar
I have the front end of the motor torn down on an '03 and cannot get the Crank Pulley Belt off. I'm using a homemade SST to hold the crank pulley with the 2 threaded holes but can't get the bolt to budge.
Suggestions?
Old Nov 14, 2011 | 03:32 PM
rworegon's Avatar
Get a buddy/SO to hold the SST while you pull on the breaker bar. Also, soak the bolt with PB Blaster. Sometimes, gentle tapping on the flange around the bolt with a hammer and blunt punch will help break the rust loose.
Old Nov 14, 2011 | 03:52 PM
fierohink's Avatar
Dumb question, is it reverse thread?
Old Nov 14, 2011 | 04:07 PM
rworegon's Avatar
Probably not, but I've not have this engine apart. There may be a thread around here that answers that question.
Added info: After looking at a few 2UZ TB threads, no one mentioned reverse threaded Crank bolt.
Sometimes trying to tighten (clockwise, righty) a bit will actually help the loosening (counter-clockwise, lefty).
Old Nov 14, 2011 | 04:49 PM
RMA's Avatar
RMA
here you go man ..
https://www.yotatech.com/forums/f28/...cement-163431/
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
