2UZ Timing Belt Help
I have the front end of the motor torn down on an '03 and cannot get the Crank Pulley Belt off. I'm using a homemade SST to hold the crank pulley with the 2 threaded holes but can't get the bolt to budge.
Suggestions? |
Get a buddy/SO to hold the SST while you pull on the breaker bar. Also, soak the bolt with PB Blaster. Sometimes, gentle tapping on the flange around the bolt with a hammer and blunt punch will help break the rust loose.
Dumb question, is it reverse thread?
Originally Posted by fierohink
(Post 51819578)
Added info: After looking at a few 2UZ TB threads, no one mentioned reverse threaded Crank bolt. Sometimes trying to tighten (clockwise, righty) a bit will actually help the loosening (counter-clockwise, lefty). |
here you go man ..
https://www.yotatech.com/forums/f28/...cement-163431/ |
