04 4R hub nut torque
Old Feb 9, 2009 | 07:18 AM
headleyj's Avatar
Hey all - I'm looking for the torque spec on the large hub nut (I guess you'd call it that, it's about 1-1/8" or so) just under the black cap on the front wheels of our 04 4Runner, 4wd.
I searched under "torque" and didn't find it. It's my wife's ride so I don't come here too awful much.....thanks!!
Josh
Old Feb 9, 2009 | 08:36 AM
GSGALLANT's Avatar
So, you're talking about the nut that threads onto the end of the CV axle, I assume?
The torque value for that nut on my 2002 4Runner is 174 ft-lb. If I recall correctly, the torque value on the 4th gen 4Runners for that nut is the same as on mine... plus or minus a few ft-lb.
You'll need to have somebody hold the brake pedal down (engine running so that you have power assist) when you're loosening/re-tightening that nut.
Old Feb 9, 2009 | 09:49 AM
headleyj's Avatar
yes the one on the end of the CV - damn 174ft lbs? Don't think my torque wrench goes that high! Yeah I did it the hard way - held the rotor still using a breaker bar wedged b/t the lugs on 1 side and a 3/4 drive ratchet on the other side, face above the rotor as hard as I could push, finally broke loose - nice mark on the side of my face when it broke loose courtesy of the dust shield
174 is your bet, k man thanks!
Josh
Old Feb 9, 2009 | 10:53 AM
GSGALLANT's Avatar
Ouch... I always pull up (use your legs... not your back) when I break those loose (instead of pushing down). It gives you a bit more control when it finally releases. The first time I did it, the torque wrench I owned only went to 150 ft-lb. I torqued it to 150 ft-lb, then gave it just a bit more for good measure (estimated the last 25 ft-lb). It hasn't caused me any grief. I now own a torque wrench that goes to 250 ft-lb (had to buy it when I started doing timing belt/water pump replacements.)
ps. be careful that you don't damage the threads on the lug bolts when you wedge something between them to keep the rotor from turning.
Old Feb 9, 2009 | 11:06 AM
headleyj's Avatar
Toyota said 150-155 ft lbs on the 4th Gen's - anyone else???
Old Feb 9, 2009 | 11:09 AM
headleyj's Avatar
Yeah I would have but my left shoulder kills when I pull up with that much force - it's bearable when I push down.
I put rags b/t the studs and the breaker - been there done that Bar wasn't long enough to wedge AND rest against the concrete either... Per my post above I'm thinkin 150 and call it good - All I've got is a Craftsman that goes to 150.
Thanks man.
Old Feb 9, 2009 | 11:18 AM
GSGALLANT's Avatar
There's a cotter pin on the 4th gens too, to prevent it from backing out, isn't there?
I'd be surprised if the 4th gen spec is 150-155, and not more like the 175 that I stated above, but in the grand scheme of things, your truck won't know the difference between the two anyways.
As for pushing vs pulling, if you must push because of a bad shoulder, I find it easier to lay down on my back and push up on the breaker bar (like bench pressing) rather than pushing down. Again, that just gives you more control.
Old Feb 9, 2009 | 11:29 AM
headleyj's Avatar
Yeah there'a a cotter pin there - I'll probably do the 150+ good measure. Yeah learned the lesson on these - break it loose BEFORE you take the damned caliper off
Thanks again man
Old Feb 9, 2009 | 12:38 PM
GSGALLANT's Avatar
No problem.
Zach_trun
Jan 22, 2020 04:42 PM
HiLuxer
Jan 6, 2016 11:34 AM
G-off
Dec 29, 2015 12:44 PM
bigtoy83
Oct 3, 2015 06:09 AM
Aaron Logan
Sep 3, 2015 08:08 AM
