worse mileage on highway
Old Jan 19, 2006 | 08:58 PM
linuxrunner's Avatar
ok what's up? i get worse mileage when i drive highway and less stop and go. when i first got the runner i made a 3 hour trip and used an entire tank on ONLY highway 55-60 in 4th - 5th entire time and got the worst mileage i have ever got like 14 mpg. i rarely drive out of the city, but i used about half of this last tank on highway only and i got 16mpg i usually only drive stop and go in the city and get about 19-20, so why is it worse on the highway?
Old Jan 19, 2006 | 09:28 PM
chopps's Avatar
What size engine do you have in the truck? Do you live in the Mountains?
Old Jan 19, 2006 | 09:31 PM
marko3xl3's Avatar
2.4L Inline 4 EFI.
No, Gladstone Oregon is not in the mountains.
No clue on why this would be happening. Crazy ECU? Leaking injectors that don't leak in the city?
Old Jan 19, 2006 | 09:37 PM
only thing i can think is that my transmission is on it's way out, so do you think that it could be causeing the motor to run faster than it should in 4th or 5th? i don't have a tach so i am not sure, but the engine sounds fine, (although i can't usually hear it about the transmission) I live at about 500ft above sea level in the valley.
Old Jan 20, 2006 | 07:40 AM
javadoody's Avatar
how fast were you running?
Old Jan 20, 2006 | 11:45 AM
I was driveing about 45 in 4th the entire time maybe once i had to stop and accelerate up to 45 from stop.
The earlyer 3 hour trip i took it was 55 in 4th and 5th the entire trip because i had to follow a trailer infront of me.
Old Jan 20, 2006 | 12:08 PM
RustBucket's Avatar
take it to the shop. Maybe you're timing's off or something basic like that.
Old Jan 20, 2006 | 12:09 PM
4Crawler's Avatar
Clutch slipping perhaps? That would explain the engine running faster than normal and that sort of thing typically occurs in 5th and 4th gear. And mayeb the O2 sensor going out, any stored codes? In town, engine runs open loop a lot, so the O2 sensor is not used a lot. On the highway, would normally be closed loop with the ECU reading the O2 and fine tuning things.
Old Jan 20, 2006 | 12:22 PM
I just reaplaced my o2 sensor about 4 months ago with oem. also i adjusted my timing about 3 months ago and it was right on. Do you think it could be off again? i dont' have a timing light, so i'll have to see if i can stir one up. The clutch does not really feel like it is slipping, what are some signs of clutch slipping?
No stored codes yay
Old Jan 20, 2006 | 12:40 PM
Does autozone or something have a timing light that you can use?
Old Jan 20, 2006 | 12:47 PM
4Crawler's Avatar
No stored codes yay
Well, driving along in 5th gear, hit the gas a bit, see the RPMs shoot up right away but the speedometer stays the same. And if you drop down a gear and repeat, then it does not slip like that.
Old Jan 21, 2006 | 12:26 AM
no tach... yet.
Old Jan 21, 2006 | 08:33 AM
javadoody's Avatar
the old school means of checking the clutch is to get the truck up to a LARGE tree--touching--and slowly let the clutch out. if the rpm is going up, and your wheels aren't digging in, that's it.
Old Jun 18, 2006 | 03:37 PM
Sonofmayhem's Avatar
if you have like the 235s they get bad gas on highway because they have to turn more, so if you have like 33s or 30s its kinda weird.
Old Jun 18, 2006 | 04:09 PM
Fo by Fo's Avatar
I don't know about you, but my 91 4runner with a V6 is at about 3k rpm or more when im at 65mph or more, and I usually shift at 3k. Maybe its just me but it seems like high rpm to be cruising in 5th gear
Old Jun 18, 2006 | 04:25 PM
Elton's Avatar
my 22re with 235s and some engine mods got 20mpg on the freeway doing 85mph turning about 3400rpms and off the freeway it got 23mpg alot better than what im driveing now but it dont bother me
Old Jun 18, 2006 | 04:34 PM
Elton's Avatar
my way of finding out the clutch was shot was to drive in 4th then put your foot all they way to the floor and if the rpms go up and your not gaining any speed then your clutch is done
Old Jun 18, 2006 | 04:42 PM
trythis's Avatar
x 3 clutch
Old Jun 19, 2006 | 11:07 AM
Chuki's Avatar
I've always just put my rig in 2nd or 3rd gear while crusin and mash the brake and gas, if you kill the engine clutch is fine, if it doesn't it slippin.
primordialbeast117
Dec 19, 2015 12:23 PM
Davebarbier
Nov 3, 2015 03:28 PM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
whiteyota93
Sep 29, 2015 02:31 PM
