Wont start. Please help real time
Old Jun 19, 2010 | 02:15 PM
jerbear's Avatar
My brother has a 1995 pick up with a 3.0 and a 5-speed. At first earlier today in ran bad and wouldn't go over 35mph. Now it won't start. Cracked open the fuel line at the injector and cranked the truck and fuel is coming out. Sprayed starting fluid in the throttle body and it starts, then dies. I am having him pull codes now by jumping TE1 and E1 on the diagnostic bay. It seems as if he has spark and fuel but its not starting. Let the opinions fly. I am trying to get him going via cell phone so I dont have to drive the hour to look at it myself. Thanks in advance.
Old Jun 19, 2010 | 02:19 PM
1981 yota's Avatar
has he checked all the fuses
Old Jun 19, 2010 | 02:24 PM
jerbear's Avatar
He has checked all the fuses and they are good. He pulled his cel code and its a 21 which is O2 sensor. He has had that for a while now, but that wouldn't stop the truck from starting, would it?
Old Jun 19, 2010 | 02:43 PM
1981 yota's Avatar
if the efi fuse was blown it would
Old Jun 19, 2010 | 03:00 PM
jerbear's Avatar
The EFI fuse is not blown and we jumpered terminals 3&5 on the EFI relay and that made no difference. Would a bad cold start injector be the cause? I only ask because it was running. Running like crap, but running. Now it will only start under ether, and dies right away when the ether is pulled away.
Old Jun 19, 2010 | 03:06 PM
Lysmachia's Avatar
Ignighter coil?
Old Jun 19, 2010 | 03:07 PM
jerbear's Avatar
Ok, if I am missing something, but if the ignitor coil were bad would it still start on ether (starting fluid)?
Old Jun 19, 2010 | 03:10 PM
Lysmachia's Avatar
If starting fluid will start the truck, it is a fuel problem. Fuel filter, or fuel pump?
Old Jun 19, 2010 | 03:14 PM
jerbear's Avatar
It is getting fuel at the rail. He cracked the bolt and my nephew turned the key and fuel came out.
Old Jun 19, 2010 | 06:13 PM
jerbear's Avatar
My brother is convinced that it is the cold start injector. Can anyone confirm or refute the possibility of the cold start injector?
Old Jun 20, 2010 | 05:28 AM
rustypigeon's Avatar
That would cause a difficult start when cold, but would not have caused the problem of running bad and not going over 35mph.
Old Jun 20, 2010 | 05:37 AM
I assume you disconnected the VAFM to do this. The truck will not run with the VAFM disconnected because it needs airflow through the meter to keep the Circuit Opening Relay energized to run the fuel pump.
coryc85
Sep 9, 2015 06:24 AM
Cplmike
Jul 8, 2015 08:47 PM
Nickdigg
Jul 7, 2015 06:04 AM
Suprarossa
Jul 6, 2015 05:21 AM
