Won't engage in 4x4
Old Sep 25, 2009 | 08:28 AM
Gsull's Avatar
Won't engage in 4x4
Hello I have a 94 4runner and 4x4 won't engage but I hear a click behind the dash. What could be wrong?
Old Sep 25, 2009 | 09:27 AM
toyota4x4907's Avatar
I had the exact same problem like 3 weeks ago. It ended up being the ADD vacuum diaphragm that switched the little sleeve onto the shaft inside the axle tube. Its VERY simple to fix.
1. Unbolt the ADD modulator on the front of the front diff axle tube. Its the thing with two vacuum hoses and an electrical plug attached to it. You can either drain the diff fluid before you do this or it will spill out once its broken loose. I did the latter because I just changed the diff fluids and didnt want to waste much. By doing it this way you save about 1/4 - 1/3 of whats in the diff.
2: Once the ADD modulator is off, its probably best to replace it with a working one, or to eliminate ADD, slide the shaft inside the axle tube into the "4wd" position so the gears are connected. Slide the fork on the ADD modulator to the 4wd side and cap off the vacuum hoses.
3: Put back together. Make sure the sleeve and fork stay in the 4wd position before you button it all back up. I practiced putting it back in without accidently moving the fork and sleeve before I applied FIPG and put it back together. Once you are able to get it back on without moving the sleeve and fork, put silicone gasket maker (FIPG) on the diff to seal the modulator back up. Fill her up with diff fluid once its all back together and check for leaks. andd make sure the 4wd engages now
If you went with blocking off the ADD, you will probably need manual hubs so the front drive-train isnt spinning and bind up. You should be able to find a used modulator at a junk yard or be able to repair the old one. How? I dont know. I just plugged mine up because I had manual hubs already. Hope this helps. good luck.
Old Sep 25, 2009 | 09:28 AM
muddpigg's Avatar
Do you know if you got a chain driven T-case?
Old Sep 25, 2009 | 10:14 AM
muddpigg's Avatar
Gsull you'd probably better go with the above post I know next to nothing about ADD. But saw a jeep with chain drive t-case that the chain was worn and slipping made a clicking big racket and no front drive. Good luck.
Old Sep 25, 2009 | 10:21 AM
4Crawler's Avatar
Check out the ADD operation:
- http://www.off-road.com/trucks4x4/ar....jsp?id=399612
westonian18
May 1, 2020 06:38 AM
Doug4320
Mar 24, 2018 10:11 PM
Tykiller1994
Aug 10, 2015 07:49 PM
94yotaky
Jul 23, 2015 07:50 AM
jgwerth
Jul 16, 2015 03:23 PM
