Wiring Harness Help 88 3.0
Old Apr 11, 2012 | 10:43 AM
islanderoffroad's Avatar
New ECU showed up today
Still no start.
Old Apr 12, 2012 | 03:27 PM
I should probably rename this thread or start a new one as we're well away from the wiring harness now, but latest updates:
So, I took the truck to a mechanic. They said I needed a new fuel pump and quoted me an obscene amount of money ($1000) for the job. I had the truck towed home, and opened the hatch under the rear seat to see how much work I was in for.
Here's an interesting one.
Is it just me or does that line look like its pinched? I've compared it to some other images of the fuel pump bracket on here and some other forums and mine just looks wrong. The PO had the fuel pump replaced by a shop last year. I'm wondering if they dropped the tank instead of using the access hatch and hit that hardline on something on the way back up.
Fuel pump working harder to get past that kink = burns out faster, plus the truck wouldn't be getting fuel as easily as it should. Thoughts?
Old May 3, 2012 | 03:02 PM
Update:
New fuel pump, filter, and pump bracket installed, truck was running again. Still had the code 22.
Bought a new pigtail for the CTS and installed it... still showing the CEL. Took a good hard look at the plugs on the back of the motor and had an epiphany. The PO said that the CEL had been on ever since he got the truck back from the engine rebuild. The plugs for the CTS and the sensor that activates the CSI were swapped. I swapped them... and no more CEL! Truck also started up much better than it did before.
Old May 3, 2012 | 03:20 PM
rokblok's Avatar
Wow, that's pretty dang cool! Good work!!
In regards to that line, someone probably tried to break the fitting loose and it twisted the line. That's my guess. Those fittings are notorious for giving problems, at least all the ones I've fiddled with.....
Old May 3, 2012 | 07:48 PM
  #25
Kiroshu's Avatar
Had the same similar problem one time on my 4runner. I replaced the head gasket a long time ago and after hooking everything back up the truck started and ran for about 2 mins then cut off and would not restart.
Code from the computer showed "thermo switch/coolant temp" forget what number but after seeing that i had a hunch that the coolant temp sensor and the cold start time switch connectors were swaped... as there are right next to each other and the same connector...
Swaped back and truck started and ran fine there after and beyond.
Oh and by the way i can't believe that shop quoted you 1000$ to replace the fuel pump when it takes all of 15 mins to change it. >_<.... Pitiful world we live in..
Old May 3, 2012 | 07:56 PM
  #26
Every professional I've talked to had no idea about the access port under the rear seat
Old May 7, 2012 | 07:06 PM
  #27
phildelfino's Avatar
"So, I took the truck to a mechanic. They said I needed a new fuel pump and quoted me an obscene amount of money ($1000) for the job."
i guess he didn't want to do the job. easier than you thought, huh?
Old Oct 31, 2012 | 08:24 PM
  #28
dodge106's Avatar
Originally Posted by worshipmentor
on the bright side, I have a complete, unmolested harness from an 88 3.0 5speed Sr5 4runner that I would put on you if you need it!
do you still have the wiring harness and also do yo9u know if a harness from a 1990 pickup is the same harness it is 4wd
Old Nov 1, 2012 | 07:17 AM
  #29
worshipmentor's Avatar
I do still have the harness. I am, however, unsure if it would work with the pickup. I suspect it would but I can't say for sure. I was going to put it in my 87 pickup until I realized the plug for the ECU on the V6 is different from the one on the 2.2 RE. Seems to me the only differences between the truck and 4runner harness may be the extra plug in harnesses that go to the tailgate and rear speakers??????
I'd gladly put it on you if you want.
Old Nov 1, 2012 | 12:55 PM
  #30
dodge106's Avatar
i will be puting it in a 1988 4runner
Old Nov 1, 2012 | 01:26 PM
  #31
Cellar's Avatar
so the fuel pump replacement fixed the surge-die-no start problem?
Hmm...
Old Nov 1, 2012 | 04:31 PM
  #32
Sorry, I misunderstood. I thought you wanted to put it in a 90 pickup.
MO transplant
Apr 23, 2023 11:58 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
msane99
Jul 17, 2015 10:13 AM
88yodabasket
Jul 13, 2015 01:32 PM
tobylab
Jul 12, 2015 12:53 PM
