Old Mar 11, 2016, 03:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical Guides
Print Wikipost
Wiring GM 1 Wire Alternator for 93 Toyota 4Runner 22RE
Old Dec 10, 2012 | 08:24 AM
too_cool_3's Avatar
Arrow Wiring GM 1 Wire Alternator for 93 Toyota 4Runner 22RE
I've searched this topic and can't find anything to clarify this question specifically for a 1 wire alt and 93-95 22RE's.
My rig is 93 4runner with a GM 1-wire alt. I have 4 gauge wire run from the post on the GM alternator to the battery. Is this the only thing required for proper operation of the alternator? Do I need to modify the stock Toyota harness and wire any of it up to another location? Or do I tape it up and leave the stock alternator plug hanging? As I understand, 93-95 Toyota's use internally regulated alternators.
I've read people re-wiring the battery indicator light, ignition and sensor wires (constant 12v and switched 12v)... Is this needed on a 1 wire GM alternator for proper operation?
Warm regards,
Marc
Old Dec 10, 2012 | 08:55 AM
beach_yota's Avatar
i second this. ive been looking for how these things need to be wired as well and cant find a whole lot
Old Dec 10, 2012 | 09:47 AM
JayKray's Avatar
I just did this in my OM617 diesel swap.
I used the original white main toyota wire, plus and additional 8 gage wire, that's it, no other wires. I've only run for about 50 miles, but I have no cel, battery, or other lights on the dash. Seems to be working fine.
Old Dec 10, 2012 | 12:24 PM
too_cool_3's Avatar
Is it correct that because the 93-95 use internally regulater alternators I don't have to worry about the new GM 1-wire alt over charging my battery? Or drawing any current when the truck is off? Basically eliminates the need for a sensor wire used on the 84-92 toyota's...
Also, because the GM alt is a 1-wire my stock toyota battery indicator light is now useless?
Old Dec 10, 2012 | 06:48 PM
too_cool_3's Avatar
I found a link to a great write up by ErikB a moderator on 4x4wire for installing a 140a Powermaster GM alternator(or any one or three wire high output alternator):
http://api.viglink.com/api/click?for...13551975778887
Here is another awesome write up for installing a Powermaster #47802 into a v6 (but is applicable to all models) by David on pirate4x4:
http://www.pirate4x4.com/forum/toyot...3-0-v-6-a.html
Old Dec 12, 2012 | 06:45 AM
Doitzel_Kaiser's Avatar
I bet if you took your rig off stock flat tires and drove it to help your buddy with his stupid 7M pickup all your problems would be solved.
Warmer regards,
Roberto
Old Dec 13, 2012 | 04:51 AM
2003mikem's Avatar
Just my 2 cents worth I did the gm 1 wire alternator and smoked 3 remaed and 1 new in 500 miles.
Just get a 12 SI 94 amp 3 wire it wires up the same as your stock yota alt but you need to sodder some wires. And your lights will work. Also.
Read my posting here.
Post #9gives a bit more info
https://www.yotatech.com/forums/f123...e-help-257812/
Old Dec 14, 2012 | 08:02 AM
Green 88's Avatar
A one wire alternator requires only one wire to work properly. If you only require stock amperage then the stock alternator battery wire is sufficient. If you require higher than stock amperage then run one wire from your one wire alternator straight to the battery in a higher gauge wire than stock. A one wire alternaotr will not/can not connect to the factory charge light.
In the old days, internaly regulated GM alternators had 3 wires. Any internaly regulated GM 3 wire alternator can easily be converted to a one wire alternator by a DIY person. If someone wants thier charge light to function and they want to use a GM alternator they will want to use one of the older 3 wire GM alternators.
There are many different versions of newer GM alternators with various amounts of wires. I think they started changing them up in the early 1990's.
vasinvictor
Jan 20, 2016 12:39 PM
bobbybouche
Jun 18, 2015 10:22 AM
JaredL
Jun 16, 2015 04:47 PM
