View Poll Results: What Head Gasket Issues Have You Had With Your 3VZE?
Never had any head gasket issues
92
38.17%
Only original head gasket recall accomplished
82
34.02%
Had 1 head gasket replaced outside the recall
53
21.99%
Had 2 head gaskets replaced outside the recall
10
4.15%
Had 3 or more head gaskets replaced outside the recall
1.66%
Voters: 241. You may not vote on this poll
Who Has NOT Had HG Issues With 3VZE?
Old Jan 7, 2011 | 08:50 AM
  #121
mattster03's Avatar
The original headgasket recall was done on my 92 4Runner in 1998 with around 90K miles on it. I bought the truck with 169K with a blown head gasket as a fix-it-up and resell project. just finished the work and am slowly falling in love with this thing and don't want to sell it!
Old Jan 11, 2011 | 01:43 PM
  #122
JR's Avatar
JR
About 330,000km (206,250miles) original headgasket never replaced.
Old Jan 11, 2011 | 02:00 PM
  #123
camo31_10.50's Avatar
No headgasket issues since i've had it.
but i see markings on the heads and block that indicate they've been to a shop before.....so sadly mines blown atleast once
Old Jan 12, 2011 | 04:06 PM
  #124
truckmike26's Avatar
I'm guessing it's never been hotter than where the needle sits on the gauge. 3VZ-Es hate getting hot. Did it ever get super hot?
Old Jan 13, 2011 | 09:46 AM
  #125
noble's Avatar
I haven't yet... Granted the pervious owner took it in for the HG recall around 60,000 miles... I bought it at 107,000 and its now around 160,000 miles... No issues as of yet (knock on wood)
Old Jan 13, 2011 | 12:59 PM
  #126
GorgeRunner's Avatar
I am unable to answer because I don't want to put the hex on my 4Runner.
Old Jan 13, 2011 | 10:18 PM
  #127
pbiker11's Avatar
My truck has never hda the HG done and teh original engine made it to 333,000 before it blew a plug out of the number 3 cylinder and it survied a few thousand miles of me beating on it with a shift rarely under 4200 rpm and frequently to 5000 plus.
Then I swapped a rebuilt engine in and it now has about 8 thousand on the rebuilt engine and it sees the same abuse and it leaks oil somewhere so its frequently low on oil,still rarely sees shifts under 4200 and more frequently sees redline because it sounds cooler tacked out. And I overheated it badly jonce when I got a pinhole in my radiator and it sprayed all the coolant out.
Old Jan 21, 2011 | 04:31 PM
  #128
jimmy riged's Avatar
i havent seen what my head gasket looks like yet lol...for three monthes i had a leaking water pump and over heated quite frequently, i've run the engine for 2 monthes everyday on a liter or 2 of oil on accident, and many other mean nasty things to it and im at 341 xxxk...im thinking the PO did the HG before me or im just ˟˟˟˟˟in horse shoes
Old Jan 22, 2011 | 04:31 PM
  #129
Reedr125's Avatar
My truck had had the hg replaced before I got it, and were blown when I got it, at 180,000. So twice so far I know of. I have looked this problem over and over. The conclusion I came to is toyota had received a shipment of bad head gaskets "substandard" is the word they used. I guess the gaskets themselves are blowing no matter what. Anyone can blow a gasket after a overheat thats common sense. But the original reason some of them blew and were recalled is the gaskets were junk. Then some people replaced the gaskets and never planed the heads, subject to another blown hg. This issue makes it hard to buy a used motor also, I would hate to pay 750 for one and its leaking and needs 400 put into it.
Old Jan 23, 2011 | 05:41 PM
  #130
89pickupsr5's Avatar
2 for me so far and a hole in a block
jashoeuh
Nov 18, 2024 08:08 AM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
clok
Aug 1, 2015 09:42 PM
Sr5crawler
Jul 31, 2015 12:32 PM
smiley52
Jul 11, 2015 05:16 AM
