Where is the Oil Pressure Gauge Wire?
Old Dec 25, 2025 | 01:58 PM
stodds's Avatar
1989 4runner SR5 with 3vze. Bought without an engine.
New engine in and can't find the oil pressure wire anywhere. Stumped. Looked for a broken wire in the harness, nothing.
Please help. Spent too much time looking for it and trying to solve. Might run a new wire directly to the instrument cluster..
Old Dec 27, 2025 | 01:08 PM
mholme's Avatar
On my ‘88, I have a single green/black wire poking out of the main wiring harness cover up by the distributor area, just below the oil fill cap.
Old Jan 1, 2026 | 06:29 PM
stodds's Avatar
are you certain this is the Oil Pressure wire? I have this wire too but it seems to connect to a capacitor that is not connected to the oil pressure switch
Old Jan 1, 2026 | 06:38 PM
mholme's Avatar
Yes, I’m certain. Mine was broken when I first got the truck and I traced it back to that wire. It’s been reconnected to the oil pressure gauge sender for over 10 years now.
Old Jan 1, 2026 | 06:39 PM
stodds's Avatar
Thank you for checking!
Is there a connector from the oil pressure sensor to this wire perhaps?
Here's what my wire of same color and location has for the other end that seems to connect with the capacitor....but maybe the capacitor connects elsewhere?
Thanks a ton. This is eating my lunch
Old Jan 1, 2026 | 07:06 PM
mholme's Avatar
The gauge wire once upon a time should have had a little slip on spade connector with a plastic housing over it to connect to the sender. Mine was MIA. Yours might be too.
I really can’t make heads or tails of your picture or what you’re referring to as a capacitor? The noise filter on the fender? Here’s how you can test the wiring for the gauge once you locate it.
d-wood
Jan 20, 2016 11:16 AM
punkelberg
Oct 7, 2014 11:55 PM
gnarlytoes
Mar 4, 2014 09:22 PM
Neil McCon
Sep 9, 2013 09:03 PM
summit4runner
Apr 3, 2011 06:14 PM
