Where to mount shocks on axle?
Old Jul 27, 2007 | 12:58 PM
Adawg_08's Avatar
Well I'm getting ready to do the Chevy Spring Swap and was wondering what you guys did for the shocks. Where did you put the lower shock mount at? Some pics would be nice. I'm buying the Sky Kit. I want to leave the top mount in the current position for now.
Also where can I get some axle shims? ( degree shims)
Thanks
Old Jul 27, 2007 | 01:44 PM
waskillywabbit's Avatar
I have Billies and I put the lower shock mount on top of the axle with the top at the stock location.
I don't like shims and didn't want to use them so I rotated my axle and perches accordingly.
Old Jul 27, 2007 | 01:48 PM
cubuff4runner's Avatar
The closer you get them to the spring pack the better.
Old Jul 27, 2007 | 01:54 PM
Elvota's Avatar
More like this ||
Less like this / \
I currently have the Sky kit and feel the angle of the shocks gives we a lot of body sway. I'll be moving them closer to the spring pack and like this || over the weekend.
Shims, I'd get steel if you have to... but agree with WabFab, perch rotation is best.
Couple sources to buy:
http://www.rubiconexpress.com/Builde...=27E4CA2911892
http://bluetorchfab.com/store/index.php?cPath=60_18
I think 4Crawler may also make custom steel ones.
http://www.4crawler.com/
Old Jul 27, 2007 | 08:40 PM
Adawg_08's Avatar
Hey thanks alot, you just saved my 60$ on a uppper shock mount from Sky.
I rember reading somewhere that the stock uppper mounts wen't located well. A shock in front and one behind really hurt flex?
I was going to ask this on pirate but you all are so much nicer over here.
Old Jul 27, 2007 | 09:01 PM
Elvota's Avatar
I am not sure if the stock location will hurt flex... depends more on the length of shock travel. I have a friend who has the stock setup (one to the front, one to the back but like this ||) and his rig works very well.
That said, if your main concern is flex, with little regard to road manners, / \ will probably be closer to what you need. Shocks angled towards the middle have about a 40% less effective rate of dampening, springs move easier. Angled can also allow for longer shocks to fit under your vehicle... so more travel, more flex.
Check out this link... has some good shock setup info:
http://www.4x4review.com/feature/shock-genius.asp
Guess it depends on the ultimate goal you have for the vehicle. I am looking for as much flex as possible, but am going to swap my shock position to this || as I think it will work better overall and have found a way to fit the same length shocks underneath so I won't loose much (if any) wheel travel.
Old Jul 27, 2007 | 09:21 PM
drew303's Avatar
wabfab has the best - easiest setup.
If you relocated the the drivers side shock exactly how it is on the pass side you'd be setup real good.
I wont go into detail as to why, apparently im completely wrong in my knowledge of how shocks work.
Old Jul 27, 2007 | 10:03 PM
Elvota's Avatar
WabFab... you got any pictures of how the upper links are attached to your rig?
What lift springs... and what length shocks did you manage to stuff under there?
Old Jul 28, 2007 | 01:06 AM
Upper links...if you mean shocks, they are attached to the stock location at the top. Driver towards the front, passenger towards the rear.
I have 5" All Pro leaf springs (all that existed practically at the time) front and rear with 12" Billies up front and 10" Billies in the rear...and a partridge in a pear tree.
(I am posting at 4 *&$*@ in the morning cause the home security system work they did yesterday decided to freaking stop working about 15 minutes ago. Somebody is going to get a good arse chewing out about 8 a.m. CST at the ADT office)
Old Jul 28, 2007 | 09:17 AM
Elvota's Avatar
Yes, shocks. Thanks for the interpretation and info.
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Scotto6591
Sep 1, 2015 03:24 PM
priest16
15
Aug 6, 2015 07:43 AM
terminator
Jul 27, 2015 07:13 PM
SMOD
Jul 27, 2015 01:45 PM
