Where to Get Discount Toyota Parts Online?
Old May 30, 2014 | 10:12 AM
wrenchtech's Avatar
I Googled and things seem to have changed since I was looking for parts a couple of years ago. Which online parts dealers do folks around here (in this forum) like best? Specifically, I'm looking for a knock sensor and knock sensor wiring harness for my V6 3.0 3VZE.
By the way, Autozone is offering a knock sensor for this application for about $127, Which is about $30 less. Is it worth considering?
Old May 30, 2014 | 10:18 AM
rworegon's Avatar
Two are in my sig line, among others.
Old May 30, 2014 | 10:29 AM
scope103's Avatar
I've had good luck with RockAuto, but those are after market parts. The only place I've found the pigtail is a dealer.
I've also had really good luck with my local dealer. They don't match online prices (why should they), but considering shipping and (mostly) time I've done quite well.
Whenever you shop for parts, don't forget your VIN. It makes it much faster to get the right part. If you go to the dealer (or any other place with a counter-man), print out the relevant drawing showing the part you want, and if you can get it, the part number you think is right. The drawings available to us are often out-of-date, but if there is a successor part number it's always easiest to find starting from the original part number.
Old May 30, 2014 | 10:32 AM
MaK92-4RnR's Avatar
Rockauto sells some Denso and NGk parts.
Old May 30, 2014 | 10:47 AM
wrenchtech's Avatar
Rock has a couple of choices for the knock sensor. At $105.99, better price than Autozone or NAPA by a good bit. Now to find the wire.
Old May 30, 2014 | 11:23 AM
wrenchtech's Avatar
My local dealer has the the pigtail wire for $14.80. Sold! I'm not gonna look further. But the sensor is $213.39. I'll have to pass on that. I might try to run with a low mileage (113k miles ;-) sensor that I have off a engine that blew a rod, but maybe not.
Old May 30, 2014 | 12:30 PM
rworegon's Avatar
The sensors themselves rarely go bad.
Old May 30, 2014 | 01:42 PM
scope103's Avatar
^ That's certainly my impression, as well.
But then, if you still have code 52 after re-using one, you've got to wonder if it might have been worth $100 just to avoid removing the plenum again. Particularly when you don't know if the sensor is the problem or not.
Old May 30, 2014 | 06:13 PM
wrenchtech's Avatar
My budget is tight, so I will probably reuse my sensor and take the risk. Need to budget for injector testing and cleaning too.
Old May 31, 2014 | 04:41 AM
the171's Avatar
-rock auto for cheap generic stuff (they have some aisin/denso/oem good parts)
-ive had good success with toyotapartscheap.com for oem parts. Pricey, but a good source for hard to find stuff.
-yotashop.com is good too. mixed oem/ aftermarket. they sell oem supplier stuff like taiho, npr, etc. good customer service and prices too.
Old May 31, 2014 | 08:03 AM
LITLRED's Avatar
I found the best price here.
OEMParts123.com
Spicer
Apr 7, 2026 07:17 PM
mtb_taco
Jun 29, 2015 06:21 AM
Chooch
Jun 19, 2015 03:05 PM
Juan Manzione
Jun 10, 2002 04:12 AM
