Where is the coolant temp SENSOR...
Old Mar 23, 2006 | 06:07 AM
mtrdrms's Avatar
89 3.0 runner. I got the part but the manual only tells me where the SENDER is not the SENSOR. One should be for the guage and one should be for the EFI. I even thought the sender was the sensor but when I looked for myself they are two different parts.
Old Mar 23, 2006 | 06:24 AM
dwh91102's Avatar
if your looking at the motor from the front of the truck, its to the left of the temp sending unit, in the same general area
Old Mar 23, 2006 | 06:53 AM
mtrdrms's Avatar
So in the back right corner of the intake manifold?
Old Mar 23, 2006 | 07:00 AM
dwh91102's Avatar
yep, move the heater hoses around and you should be able to see it.
Old Mar 23, 2006 | 07:03 AM
snap-on's Avatar
see "water bypass parts for a $1000"
https://www.yotatech.com/forums/f116/name-those-water-bypass-parts-74247/
Old Mar 23, 2006 | 07:07 AM
eric-the-red's Avatar
Yes, and it's a pita to get at
Old Mar 23, 2006 | 07:33 AM
mtrdrms's Avatar
There is 4 of them in a row back there and none seem to have the same connector as the one I bought? Which one is it? Anyone know off hand?
Old Mar 23, 2006 | 07:43 AM
mtrdrms's Avatar
https://www.yotatech.com/forums/showthread.php?t=74247
This appears to be a different setup than mine. Mine has 4 connectors in a row and a water tube on either side. They seem to be the same fittings and perform the same purpse but are jsut in different locations. What engine is that photo from?
Old Mar 23, 2006 | 07:59 AM
snap-on's Avatar
ummmm somthing like a 90 3vze. they changed the stuff back for various years and models.
the one on my 94 truck is diffrent from the one on my 92 4runner which is diffrent than the one you see in the pic.
i was under the impression that the colors of the connectors would be the same (although they might not be in the same locations)
jb451
7
Oct 7, 2022 06:58 AM
Boomer8404
Sep 20, 2015 06:15 PM
LotOMiles
Sep 14, 2015 11:45 PM
noahstancik
Sep 10, 2015 10:47 AM
--Oz--
Sep 6, 2015 01:06 AM
