When replacing a driveshaft
Old Jan 5, 2009 | 11:22 AM
Jay351's Avatar
Originally Posted by muddpigg
I don't think you can blame that on the wrench. Looks more like operators "head space and timing."
Haha, there is no need to torque those bolts down. Use a small rachet and just do em till they are snug. Its not holding the truck together
Old Jan 5, 2009 | 05:28 PM
Windsor's Avatar
Originally Posted by Yotas&Jellos
Okay, I have one more question! (I think) I was checking out the FSM on removing the the drive shaft. After you remove it from the transmission it says plug it with an "SST" and I was wondering what this is.
Butt plug for your transmission, only required for 2wd.
The 2wd driveshaft seals the rear of the transmission, so when you pull it out, you have an opening to pour gear oil all over your chest and shoulders when you start moving the transmission down. (1st-gen RX-7s are the same way)
If you don't have the tranny butt-plug, just drain all of the oil first and then stuff a rag around the output shaft after pulling the driveshaft.
4x4s transmissions are bolted up to xfer case, so you don't need to worry about it.
Old Jan 5, 2009 | 08:33 PM
Yotas&Jellos's Avatar
Thanks yota4runna and Windsor!!
I was wondering about both of those and they help a lot! Cool.
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
1994toyota
Jul 17, 2015 03:03 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
