Whats wrong?
Old Feb 18, 2013 | 07:46 AM
StewsRunner's Avatar
Okay well if it only starts well about 30% of the time in the morning, what I just told you may be irrelevant. .
Old Feb 18, 2013 | 11:15 AM
bone collector's Avatar
Change your fuel filter
Old Feb 18, 2013 | 12:19 PM
4runner20's Avatar
Bare with me here but, where is the fuel filter located?
Old Feb 18, 2013 | 12:25 PM
4runner20's Avatar
Old Feb 18, 2013 | 12:33 PM
  #25
Passenger side frame rail. Tucked behind the torsion bar. Its a lot of fun
Old Feb 18, 2013 | 12:35 PM
  #26
4runner20's Avatar
Okay. Thanks. Gotta learn somehow! Haha
Old Feb 18, 2013 | 01:17 PM
  #27
scope103's Avatar
Originally Posted by 4runner20
Cranking it a little longer while giving a little gas will start it about 70% of the time. If it doesn't I just turn the key to lock then crank again and it will start right up
This sounds like a bad check valve in the fuel pump. As Co_94_PU says, the fuel pump does not run until the key is turned to START. Ordinarily, the check valve in the fuel pump holds pressure in the rail, so it's right there the next time you want to start. If the check valve fails, the pressure leaks back into the tank, and the pump has to run for a few seconds to bring the pressure up far enough to start.
The positive diagnosis is to install a fuel pressure gauge and watch it when you shut down, and start up. Replacing the fuel pump (the check valve is not available separately) is a bit of work, and I'd want to be sure this diagnosis was correct before I did that.
By the way, if the truck runs well once it starts, it's probably not the fuel filter. It's probably a good idea to replace it in a 12-yr old truck, but it is no picnic to change.
Steven.m.paulk
Jun 7, 2020 10:45 AM
zytra
Jan 24, 2019 03:16 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
charlie_fong
Sep 27, 2015 10:06 PM
