What Will ethanol Do To My 91 Runner
Old Jun 9, 2006 | 02:40 PM
DaShry1's Avatar
I have read plenty of threads on this forum but cannot find what will hapen if I burn an ethanol based fuel. I have seen a thread where someone posteed that the injectors are not compatiable are there any available for the 91 4Runner w/a 3.0?
Old Jun 9, 2006 | 03:03 PM
brandontrek's Avatar
not run from what i have read...our injectors are too...how should i put it....crappy...
Old Jun 9, 2006 | 09:41 PM
trythis's Avatar
there is a fairly long thread, hijacked of course, maybe several times, at 4x4wire on this topic. Lots of experiments and lots of politics. It is in the toyota section.
I looked into the conversions that are available. Noone sells a toyota conversion, and no toyotas can use ethonal. I think it is becasue all the rubber used in the fuel system is rubber and the acid will destroy the seals and fuel lines. You could probably run a while on ethonal, as some have reported to have no problems at teh above mentioned thread at 4x4wire.com. I am guessing there are so many parts to trade out that aftermarket companies can't make a converion kit to a polyethylene fuel system.
I am guessing, no real knowledge.
Old Jun 10, 2006 | 12:16 PM
Marc's Avatar
Are you talking about pure ethanol or a 10%-15% blend?
Old Jun 10, 2006 | 01:20 PM
91Toyota4x4's Avatar
I'm sure they are referring to a blend.
Old Jun 10, 2006 | 04:46 PM
Marc's Avatar
My manual indicates using 10% ethanol is ok.
I know in some states that's all that's available.
Perhaps there aren't any Toyotas in those states.
Old Jun 10, 2006 | 07:44 PM
DaShry1's Avatar
I was talking about both blends 10% and e85 here in the houston area by the middle of next year Krogers will only offer e85 and nothing else thanks sofar for the info.
Old Jun 10, 2006 | 08:32 PM
NicksBlue934runner's Avatar
10% states
marc i live in missouri and all i can get is a 10% blend and this is personally my 2nd yota
mom has a prius
uncle has a taco
and the list goes on
icentropy
Sep 16, 2020 02:47 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
