31's on a 4x2???
Old Jun 8, 2006 | 02:55 PM
fuel36's Avatar
31's on a 4x2???
I have a 1995 4runner 4x2 that i am about to put new tires on. it currently has 235's but it comes stock with 225's so i am wondering if anyone knows if it will tuck 31's like all the 4x4's come with.
Old Jun 8, 2006 | 03:06 PM
surf4runner's Avatar
i have them on my p/u but it has a 3" lift.
same on a 4runner???
Old Jun 8, 2006 | 03:20 PM
kyle_22r's Avatar
most 4x4s came with 225/75R15s stock. i think you'll need a body lift to fit 31s on a 2wd truck.
Old Jun 8, 2006 | 03:38 PM
fuel36's Avatar
i alredy thought of the body lift but i have an automatic and from what i've heard you cant put a body lift of an auto so i guess ill just have to go with 225's or 235's
Old Jun 8, 2006 | 03:49 PM
Sonofmayhem's Avatar
naaa you can too, body lifts usually come w/ steering extensions, shifter extensions and so forth. you should be able to fit 30s.
Old Jun 8, 2006 | 04:20 PM
Paul H.'s Avatar
Many of the 4x4 4runners came with 225's also. you should have no problem fitting 31's.
Old Jun 8, 2006 | 04:25 PM
tc's Avatar
tc
Uh, guys the suspension is TOTALLY different. The analogies to 4WD don't apply AT ALL.
I had the old Fabtech Ivan Dan longtravel lift on my 2WD (7" lift IIRC) and 31x10.50 STILL rubbed pretty significantly. They were on KMC rims - no idea what the backspacing was.
Old Jun 8, 2006 | 04:48 PM
Paul H.'s Avatar
Ok, did not realize that, thanks tc.
Old Jun 8, 2006 | 05:07 PM
95RunnerSR5's Avatar
you can get up to a 3" body lift from 4crawler.com they come with extensions for your shift linkage
Old Jun 9, 2006 | 07:46 AM
L33T35T 4Runner's Avatar
31s will fit fine on a 2wd 95 4runner. ive been running 31s ever since i got it
Old Jun 10, 2006 | 09:08 PM
ToyoRunner94's Avatar
my first 4runner was 2wd and i ran 31 BFG AT's with no problems. the 31's will dramatically change the appearance, i would highly recommend it
jasonty
41
Dec 23, 2018 01:00 PM
Rcbc92
Sep 26, 2015 03:00 PM
teknovls
Aug 9, 2015 12:37 AM
Tigbucket
Jul 30, 2015 07:29 PM
paranoidandroid
Jul 3, 2005 10:49 AM
