What is this thing called?
Old Feb 17, 2009 | 03:18 PM
toybota's Avatar
What is this thing? I know it is part of a shifter linkage but does anyone know the technical name of it? Also where can I get one? If anyone has one for sale consider it sold and pm me. Thank you to all ~Derek
Attached Thumbnails What is this thing called?-0217091835.jpg   What is this thing called?-0217091836.jpg
Old Feb 17, 2009 | 03:21 PM
abecedarian's Avatar
If you don't know what it is or what it does, how can you be sure your's is bad and you need a new one?
Old Feb 17, 2009 | 03:31 PM
toybota's Avatar
As you can tell from the picture the joint inside the shaft is off center and does not line up parallel with the housing it sits in. Also with movement(by hand) I can recreate the sound that I hear when driving. It has much more movement then is necessary for smooth movement of any shaft. Kinda like a worn ball joint. Excessive movement i believe is what mechanics would call it. I was not asking if it is bad but what it is called so I can order one or replace it. If you know I would greatly appreciate you knowledge.
scuba's Avatar
Looks Like a custom transfer case crossmember..
Old Feb 17, 2009 | 03:40 PM
dropzone's Avatar
Fossilized
When asking for a random part it helps to specify a few things such as:
-year of truck
-engine
-auto or manual transmission
as far as sources google turned up sources like:
http://www.yotayard.com/
http://www.davezoffroadperformance.com/contact.html i have bought used stuff from him before
http://www.calminitruck.com/
there is ton more out there
also consider getting a photobucket.com account...those little thumbnails suck
edit: you can also try going to the link to online service manuals in my signature
Old Feb 17, 2009 | 04:15 PM
space-junk's Avatar
look here...
post 435... DIRTCO explains what it is...
https://www.yotatech.com/forums/f116...0/index18.html
Old Feb 17, 2009 | 04:20 PM
fireman1559's Avatar
i will make it easy for you if you follow the linkage straight up it will lead to you shifter for your 4wheel drive
Old Feb 17, 2009 | 05:09 PM
toybota's Avatar
Thank you so much for clearing that up for me. So that is the 4wd drive linkage assembly and makes it possible for the shifter to be on the opposite side of the truck as the transfer case. Thank you for helping me out with this. ~Derek
Old Feb 17, 2009 | 05:18 PM
RMA's Avatar
RMA
try this
http://www.4crawler.com/4x4/ForSale/...Tbracket02.jpg
and this
Old Feb 18, 2009 | 06:54 AM
Bobzombie's Avatar
Cross shaft sub assy. part number 33709-35110 $100.91
cross shaft bracket part number 33793-35010 $34.67
NEW FROM TOYOTA
Old Feb 18, 2009 | 07:45 AM
ricky's Avatar
It helps if you actually click on the thumbnail
Old Feb 18, 2009 | 08:47 AM
mt_goat's Avatar
Do you have a body lift? That linkage attaches to the body at the top and when I installed a 1" BL on mine I had to lower that attachment point to keep the linkage pivot point working good.
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
thzpcs
Oct 3, 2015 07:39 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
