What is this, and should it be plugged in?
Old Aug 12, 2009 | 06:44 PM
Erik Beeman's Avatar
No, the water temp sensor is in the front of the intake manifold, a little bit in front of the thermostat housing.
I still havent found a plug, and personally, I don't think this vehicle has that knock sensor. I think the motor was swapped out before I bought it with a 4wd block, possibly. Although, it is weird that my 88 2WD does have it. I gave up, and said forget it, unless somebody can PROMISE me FOR SURE that this motor has a knock sensor.
The only thing left for me to check are the pins on the ECU, to see if there is a pin for a knock sensor. If there is no pin, then the ECU isn't set up for the knock sensor. I went to look up the pins in the factory manual online, and for this 2WD, there is no pin number or location on any of the connectors.
Old Aug 12, 2009 | 06:53 PM
iamsuperbleeder's Avatar
I don't see that it would matter between 2wd and 4wd
the running of the motor has nothing to do with weather or not there's a front diff under the motor, for the most part...
2wd or 4wd, it's still capable of knocking from pre-ignition
Old Aug 12, 2009 | 07:08 PM
Ok then, why does Toyota's factory manual say "Knock Sensor (4WD Only)"?? Still don't know if mine has it or not. I need to check the ECU to see if it has the knock sensor pin, but I can't even find the ECU diagram of pins...doh
Old Aug 12, 2009 | 07:15 PM
Old Aug 12, 2009 | 07:35 PM
  #25
I do not have a Knock sensor.
I have this ECU In my truck.
Old Aug 13, 2009 | 01:23 PM
  #26
that's pretty strange, but good searching and finding if only everyone was so determined
I just find it odd that it actually does matter between 2wd and 4wd but whatever, lol
80Truck
Oct 12, 2025 07:25 PM
Blamalam
Mar 12, 2022 07:34 AM
old87yota
Oct 25, 2015 02:15 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
msane99
Jul 17, 2015 10:13 AM
