What's this connector go to??
Old Mar 3, 2009 | 03:07 PM
qdude79's Avatar
Trying to troubleshoot my A/C VSV and came across this little orphan:
Is this direct injection for the 1.21 jigawatts?
Old Mar 3, 2009 | 03:09 PM
abecedarian's Avatar
looks like the plug to the EGR EGT sensor... if I'm not mistaken.
Old Mar 3, 2009 | 03:10 PM
by the way, where's the clamp on the valve cover fresh air intake hose? (right next to the "Y" on the "TOYOTA" on the valve cover)
Old Mar 3, 2009 | 03:11 PM
qdude79's Avatar
Familiar with the dreaded EGR, "EGT" not so much... please enlighten.
Old Mar 3, 2009 | 03:12 PM
Exhaust Gas Temperature. Little sensor on the EGR valve.
edit- can see it here on this pic, right above the intake manifold:
Old Mar 3, 2009 | 03:17 PM
toyota4x4907's Avatar
The EGT is only on 22rec's, correct?
Old Mar 3, 2009 | 03:20 PM
Well, the pic is of a California 22RE (per the underhood sticker) so... maybe... and my 88 has the same connector but is California 22RE (per the sticker)... (but the connector is green)?
California emissions vehicles pass emissions nearly everywhere so it's feasible that a Cali truck was shipped to meet demand?
Old Mar 3, 2009 | 03:25 PM
Nevermind... the truck in question (qdude79's truck) is a Cali truck.
Old Mar 3, 2009 | 03:26 PM
Its not important to me, I was really only curious. All the diagrams I have seen of the emissions stuff for these 4runners have that on Cali only vehicles.
I'd go look on mine but the hood is frozen shut
Old Mar 3, 2009 | 03:28 PM
my sympathies. It's pushing into the 70's F here.
Old Mar 3, 2009 | 03:31 PM
qdude79's Avatar
Does the other end come out of the top of where your EGR mates to the intake? I see nothing like that on mine.
PS- Why you starin' at my tubes? I could report you!!
Old Mar 3, 2009 | 03:33 PM
qdude79's Avatar
Another "benefit" of being in California...
Guess I'll just go play with my lonely EGT connector.
Old Mar 3, 2009 | 03:40 PM
Tubbyfatty's Avatar
I wish it was close to 70 up here. Its going to be 50s and raining most of the time all week.
Old Mar 3, 2009 | 03:44 PM
please keep your tubes to yourself.
showed you a pic of a 91 22RE (cali) with the connector and sensor.
DOES NOT MEAN your 90 has the same EGR- may have been imported for all we know but had the provisions for the sensor and the ECU wasn't equipped for it.
If you're not getting a trouble code 71, I wouldn't worry about it much, particularly if you pass emissions testing.
I don't know what the temp is, but its warm enough that I can stay outside in a t-shirt comfortably...that could be anywhere between -10 and 80 though..
You know you like it
I don't remember seeing the EGT on my '93 22re. Is is possible yours is from some other state?
Will it pass Cali emissions without it if it is not a 22rec?
Old Mar 3, 2009 | 03:49 PM
I
Weren't all Toyotas imported back then?
Old Mar 3, 2009 | 03:52 PM
imported into cali from destinations unknown.
Old Mar 3, 2009 | 03:56 PM
iamsuperbleeder's Avatar
huh, well no EGR temps sensor, so that explains what that dangling plug it
I've always about that, but never bothered to ask cause the truck ran fine without it plugged into anything
Old Mar 3, 2009 | 03:58 PM
qdude79's Avatar
Passed with colors that were flying...
Old Mar 3, 2009 | 04:02 PM
It's more of a feedback to the ECU about things than some requirement for emissions. At the very least it's a head's up if the EGR passages are blocked since that will cause the EGR temp to be low. But if you don't have the sensor and pass your tests, then you should be fine.
