What is this plug?
Old Feb 24, 2013 | 10:56 AM
Starcitygta's Avatar
What is this plug?
I have a 88 4runner 3.0 auto I know lucky me lol but what is this plug ? Could it be knock sensor conector wire ? I do have code 52 any help would be appreciated
Old Feb 24, 2013 | 11:21 AM
Inferno451's Avatar
I don't have a 3.0 anymore, but it sure looks like that could be it. Check out this link: http://www.toyota-4runner.org/classi...-location.html.
Welcome to Yotatech!
Old Feb 24, 2013 | 12:56 PM
Thanks inferno I'm hoping to get this thing my dd real soon if I can iron out the code 52 blues
Old Feb 24, 2013 | 02:14 PM
MudHippy's Avatar
It connects to the knock sensor wire underneath the throttle body(via the knock sensor wire connector shown below, the connector types shown in the link are the 92-95 style).
Old Feb 24, 2013 | 02:29 PM
So u have to remove the throttle body to get to it or can it be just plugged in? I'm looking everywhere and can't locate that part u show sure wish I could I'm dying to get this girl right
Old Feb 24, 2013 | 02:35 PM
MudHippy's Avatar
You might have to remove the air intake hose from the throttle body, but probably not the entire throttle body(though it might be easier if you did). I can plug/unplug mine without even removing the hose(but yours might be more difficult).
If you can't find it right where it should be(underneath and just to the right of the throttle body), then maybe it's missing?
Old Feb 24, 2013 | 02:43 PM
Yeah I pulled the intake hose off I think it's missing or buried I'm going to take it to a good mech to try and finish this thing up. The harness that I show in the pic is badly frayed, can it be replaced or is it part of the main harness? Also mudhippy is there anything else that should be done while I'm have the knock sensor/ wire done? Thanks for all the safe advice
Old Feb 25, 2013 | 06:19 AM
MudHippy's Avatar
It would be a nightmare to replace those wires, since they are part of the "main"/engine harness. Maybe you can cut out the frayed end(s) there and splice in new wire(s).
...is there anything else that should be done while I'm have the knock sensor/ wire done?
Not if everything else is working as it should be. I'm more of the if it ain't broke, don't fix it type. Though you could have them check the valve clearances for you, since the plenum chamber will likely be removed(and likely the intake manifold too). Which may or may not result in having the valves adjusted too(if they're too tight).
Hey, you should help this guy out. Consider it a return favor...for me helping you.
https://www.yotatech.com/forums/f116...outing-265864/
Old Feb 25, 2013 | 01:21 PM
Thanks mudhippy will do would be glad to help. Mine is going in the shop Friday to get a new wire pigtail I hope this gets mine on the road as a daily driver I'm gonna gamble on the sensor being ok seeing a they rarely go bad and it's unhooked now.
Old Feb 27, 2013 | 02:59 PM
Well my mechanic has it tore down and the wire was missing. Mudhippy u were dead on like always. There was a bi metal temp switch in the back behind intake that was bad it had to be order from toy so it's gonna be Friday before she is buttoned up I hope I did right by not buying a new knock sensor but with the wire gone I'm hoping that's all it is
Old Mar 2, 2013 | 10:22 PM
Well, I picked her up today and no check engine light is on fingers crossed. It is running pretty good I have overdrive now code 52 is a real pain. One problem I am still having is it has a slight wiggle or shake the trans feels fine I think it just needs the harness cleaned and fresh lube. Seems like I read where that cured another simLr issue on here. The thing use to drop oil like the Exxon Valde or whatever lol. Wish me luck
Old Mar 3, 2013 | 05:58 AM
Maybe even a jerk feeling
80Truck
Oct 12, 2025 07:25 PM
Blamalam
Mar 12, 2022 07:34 AM
old87yota
Oct 25, 2015 02:15 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
msane99
Jul 17, 2015 10:13 AM
