What is this part?
Old Jul 22, 2008 | 04:15 PM
bikerbob's Avatar
What is this part?
I have looked in my Haynes manual can can't figure out what this is. The part I am interested in is the black box which the cable coming out one end and wires on the other. The wires go through the firewall and the cable goes to the same linkage as the throttle cable. I have never see the cable move. It is slack every time I look at it.
Old Jul 22, 2008 | 04:19 PM
Elton's Avatar
cruise control box ? gee ive never seen that b4 new one on me
Old Jul 22, 2008 | 04:26 PM
iamsuperbleeder's Avatar
that's about the only thing it could possibly be is a cruise ontrol box...
not having cruise control, I cannot back that up though...
"is it OEM" is another question though... the non-sleeved wires lead me to believe it's not an original part and may have been installed by the PO... can you find TOYOTA stamped anywhere on it? it so, it's more than likely got a part # stamped on it too... if you can find it, try to google the part #
Old Jul 22, 2008 | 04:27 PM
NicCantDecide's Avatar
that doesn't look stock, could be an aftermarket alarm system. Do you have one?
The cruise control box in my 93 4Runner (V6) looks nothing like that and the cable for it is nowhere near that gimpy. Same gauge as the throttle cable.
Old Jul 22, 2008 | 04:30 PM
hurley842002's Avatar
I've never seen on a Toy, also if it was factory that rainbow of wires coming from it would be wrapped in something (unless of course a covering was ripped off). Actually looking closer, that wiring doesn't look like its coming from it. I can't tell, but either way it doesn't look factory.
Old Jul 22, 2008 | 04:33 PM
Elton's Avatar
where do the wires go too ?
Old Jul 22, 2008 | 04:37 PM
bikerbob's Avatar
I haven't followed the wires yet but I will.
Yes, it does have an after market alarm system.
Old Jul 22, 2008 | 04:39 PM
Crawdad's Avatar
It's an aftermarket cruise control setup.
Here's another one, though it looks a little different.
http://www.ekeystone.com/images/00/p...A24/cruise.jpg
The previous owner probably lost the in-cab module.
Old Jul 22, 2008 | 05:43 PM
HAVOC's Avatar
It's what crawdad said. An aftermarket cruise control unit. Does the cruise work? Or are you just curious on what it does?
Old Jul 22, 2008 | 06:25 PM
bikerbob's Avatar
I didn't even know I had cruise control. I can't find any switches in the cab for it. I went and looked and found three switches/ buttons I hadn't seem before And I only what one is for, it's the valet switch for the alarm. The previous owner did a lot of extra wiring.
Targetnut's Avatar
It's an aftermarket cruise control and the cable is not hooked up correctly at the throttle. It needs to follow the throttle cable around the bellcrank. And they are usually tied together just off of the bell crank with a very small cable tie.
Old Jul 22, 2008 | 06:50 PM
Crawdad's Avatar
Yes, it probably slipped off (because it wasn't tied down as you described) and that's why there's extra slack.
If you find a model number on the cruise control unit itself you can probably find a control module for it - there is going to be a plug under the dash somewhere that those multi-colored wires go to. Maybe. If it still works.
Old Jul 23, 2008 | 04:36 AM
scrid's Avatar
Aftermarket cruise.
Heres a similar one.
http://cgi.ebay.com/VW-94-JETTA-Crui...QQcmdZViewItem
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
