What is it doing in my oil pan?
Old Mar 29, 2009 | 08:12 PM
91Toyota's Avatar
Originally Posted by iamsuperbleeder
lol, I think that was just for size refference guys
How about the wood...was that in there too
Old Mar 29, 2009 | 08:21 PM
YoYoMa's Avatar
Size reference folks come on.
Old Mar 29, 2009 | 09:38 PM
annoyingrob's Avatar
Originally Posted by 3VZRUNNA
i hate changing the pcv valave. pieces of shizz got stuck in the valve cover and i had to remove those pieces of shizz with 90 degree needle nose pliers
I got rid of that dumb piece of rubber or plastic, or watever it was a while ago, and slid a piece of silicone tubing over the end of the PCV. Creates a perfect seal. Hard to see in this picture, but the larger diameter silicone hose I had (seen attached to the lower breather on the valve cover) was a perfect diameter and thickness to wedge between the PCV valve, and the hole in the valve cover.
As for those pieces damaging the motor, when the guides broke in my Celica, it ran for a week with little to no oil pressure. Then my brother replaced them. The timing cover was already leaking. All of the coolant ended in the oil. He drove it like this for a few days, with no coolant in the cooling system, and coolant in the oil. He brought it home, I pulled the head off, replaced the head gasket and head bolts (the head gasket was starting to leak too. Fun motor), replaced the timing cover, flushed the oil, and it ran as good as ever. That was probably 8 months ago, and he still drives it daily, and it's still running like a champ.
Edit: spelling.
Old Mar 29, 2009 | 09:58 PM
xzyragon's Avatar
Edit: spelling.
painted valve covers add 5 HP dontcha know
clean looking engine though
Old Mar 29, 2009 | 10:08 PM
  #25
BLKNBLU's Avatar
Originally Posted by YoYoMa
Yeah, I had noticed some screetching and or clicking while under load but i had accounted that to the transmission giving out. I also took it to a local 22r guy with GREAT references to peek at it before i started everything, he said everything was perfect other than the exhaust leak and oil pan gasket. When I did the valve adjustment and new VC gaskets I peeked down the timing cover to check the conditions of everything but, couldnt see down far enough to get a good looksee. The previous owner said the timing chain was replaced with one that had metal guides I guess I will find out tomarrow. If it was or wasnt replaced with metal idk but the mechanic who did the jub rplaced the pan gasket with RTV...that leaked......alot...for a looong time.
It is likely the PO did have the chain and guides replaced but whoever did the job didn't bother to drop the pan to check for pieces of the old guides. That would also account for the leaky oil pan since it's harder (but not impossible) to get a good seal if you replace the timing cover without dropping the pan.
Old Mar 29, 2009 | 10:27 PM
  #26
91Toyota's Avatar
looks like a turbo to me^^^
Old Mar 29, 2009 | 10:31 PM
  #27
StangBanger's Avatar
Man.. i miss my old 22-re
Old Mar 29, 2009 | 10:41 PM
  #28
Plumbrbob's Avatar
this is possible cause I am guilty for doing it and have asked others if they dropped thier pan and they jsut took the short cut 9 out of 10
Old Mar 30, 2009 | 12:02 AM
  #29
toyota4x4907's Avatar
22r-e if ya wanna get technical
Old Mar 30, 2009 | 01:45 PM
  #30
lethe's Avatar
x2. you can kind of see the word turbo in the intake manifold.
Old Mar 30, 2009 | 01:55 PM
  #31
83's Avatar
83
Isn't the oil pan meant to be sealed with just RTV, no actual gasket? If it's done right it won't leak.
Old Mar 30, 2009 | 02:00 PM
  #32
INFINITY's Avatar
chain guide chunks
Old Mar 30, 2009 | 03:16 PM
  #33
vwfastg60's Avatar
Originally Posted by INFINITY
chain guide chunks
X2
I kinda miss my 22rte
Old Mar 30, 2009 | 03:35 PM
  #34
YoYoMa's Avatar
As it turns out, the PO lied yet again (no suprise) and while the timing chain had been replaced it was plastic (not broken, but this don't mean the plastic wasn't from before it was changed buy the PO). Didn't plan for this to turn into a timing job. Gotta give a shout out to Nor-Crawl though. They had a new metal timing set and gave it to me for next to nothing....and it all started with a rattle.
Old Mar 30, 2009 | 04:10 PM
  #35
YoYoMa's Avatar
Upon closer inspection:
A beer to all that said guides
Old Mar 30, 2009 | 04:21 PM
  #36
BigBluePile's Avatar
Nice, that sux dude!!! Atleast, when it's done, YOU'LL know it's GTG!!!!!
Old Mar 30, 2009 | 05:15 PM
  #37
YoYoMa's Avatar
I am glad I had decided to go through the truck. If I hadn't I think I would have been very upset in a few short months.
Old Mar 30, 2009 | 05:59 PM
  #38
iamsuperbleeder's Avatar
lol, it always does
good ya found the couplrit
now get 'er fixed!
Old Mar 31, 2009 | 06:31 AM
  #39
That's because it is . I had the valve cover off for a valve lash adjustment, and decided to paint it.
As for the oil pan, my 83 22R-E (early efi!) Had a gasket on it. Most of my other toyota motors.have been rtv. The only other pan gasket I've seen was on a 5M-E.
Old Mar 31, 2009 | 08:21 AM
  #40
YoYoMa's Avatar
Why RTV? I can't say I have ever seen an RTV'd gasket that held up as well as a cork or silicone gasket. Plus, after time doesn't RTV dissolve then re-solidify in the most innoportune place?
