What is this cable for?
Old Nov 2, 2021 | 11:21 AM
JomiG888's Avatar
What is this cable for? 94 4runner 3vze
Just found it hanging loose.
Last edited by JomiG888; Nov 2, 2021 at 11:24 AM. Reason: Oh yeah its a 94 4runner 3vze
Old Nov 2, 2021 | 03:06 PM
BigBluePile's Avatar
Probably for your ADD according to your remarks....94 4runner 3vz...
Old Nov 3, 2021 | 06:29 AM
COMTB's Avatar
Yep, has to do with your 4wd/ADD system. I'm not sure if it's actually needed to engage 4wd or not to be honest since when I swapped to a 5vz that plug was no longer used and just the vacuum lines were hooked up.
Old Nov 3, 2021 | 06:49 AM
scope103's Avatar
BigBluePile is almost certainly correct (it could help if you got more dirty grease in the picture, and maybe shoot into the sun).
Looking aft toward front differential.
Old Nov 3, 2021 | 06:52 AM
scope103's Avatar
The wire is for the "4wd" light. If the vacuum lines are connected correctly, the wire isn't needed to engage 4wd, it's just to tell you if it engaged.
SomedayJ
Feb 25, 2020 02:45 AM
green9422re
Dec 28, 2010 11:46 PM
TC4RNR
May 10, 2008 07:30 PM
treknwil
Dec 31, 2007 08:36 PM
