Werid, Clutch wont release
Old Dec 19, 2009 | 02:54 PM
shaeff's Avatar
Stupid question:
Is the transfer case stick in gear? If you've got that in neutral, guess what? Yep, you're in neutral no matter what gear you put it in.
Make sure the transfer case is engaged in 2wd, or 4wd, and not in the neutral position. Then put the truck in first gear and see what happens.
Old Dec 19, 2009 | 03:03 PM
vital22re's Avatar
totally a bro
x2 on shaeff. Also Try unbolting the slave cylinder, pull the boot off from around the tranny. Then try moving the shift fork. ONLY WITH SLAVE OUT OF THE WAY! otherwise if the slave is stuck/rusted, you wont be able to release the clutch.
Old Dec 19, 2009 | 03:10 PM
Matt90V6SR5's Avatar
OP hasnt posted in 6 days,he must have figured it out.
Old Jan 6, 2010 | 10:14 PM
toad559's Avatar
what was the problem and how it get fix? i ot almost the same problem
Old Apr 28, 2010 | 05:57 PM
  #25
Matt4Running's Avatar
Well it sure was a WERID problem he had in NETURAL.Of course I have no clue what werid and netural means,lmao.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
