well I just finishing installing lift.
Old Jul 1, 2009 | 08:19 PM
4Crawler's Avatar
Originally Posted by 1990mudslut
I do have one mroe question tho,You don't think that the steering shaft will pop back out of place in the steering wheel do you?is there a way I can check this?
Not sure what part you are talking about, but if this is the actual shaft into the steering wheel, the only way that will pull out is if the nut holding the steering wheel in place is missing. If it is the clamp at the firewall:
Then the clamp bolt will hold that in place. The purpose of the spacer is to allow the shaft to push into the clamp far enough to allow it to hold it securely. In fact the black mark on the shaft shows the amount it pulls out due to a 2" body lift (I went from 1" to 3" lift, marking the position at 1"). So the spacer is of course thinner than the lift is tall.
Old Jul 1, 2009 | 08:26 PM
1990mudslut's Avatar
Well I can't explain what was popping out but I do know for a fact that when the two shafts were apart at the end waiting for the extension the shaft weight pulled it out of a joint? or something idk all I know is the shafts were all tight outside and inside the firewall but it was popping out somewhere in the steering wheel.Do you recommend me removing the steering wheel and seeing what is up?
Old Jul 1, 2009 | 08:57 PM
4Crawler's Avatar
Probably pulled out of the top clamp (pictured above). But it may be a good idea to find out where the popping sound is coming from. Never heard of that happening before, so no ideas on what it may be.
Old Jul 1, 2009 | 09:04 PM
well i don't mean popping as a sound even tho it did that I mean something was pulling out in the steering wheel assembly like the steering will could spin all it wanted and would turn a single shaft.
Old Jul 2, 2009 | 06:33 AM
  #25
4Crawler's Avatar
Well if the shaft pulled out of the upper clamp the steering wheel of course would spin freely. If putting int he spacer and reinserting the lower shaft into the upper clamp fixes that problem, then all is normal. If it does not fix the spinning problem, then something else is going on.
Old Jul 2, 2009 | 01:02 PM
  #26
well I got up this morning to work on the firewall and the plate is not adjustable in any way what so ever It is in a indention designed for that plate to sit in,it is help in by 6 bolts and the plate has tapped threads there was no moving it without drilling new holes and longer bolts so I said the hell with it and got a flathead screw driver and hammer and bent the firewall enough for the clearance of the steering shaft.All seems to be well except the play in the steering wheel but ill get used to it.
Old Jul 2, 2009 | 01:59 PM
  #27
4Crawler's Avatar
That works as well, whatever is takes to get clearance for the shaft. I guess the later trucks have a different design, my '85 has the 3 bolts and is adjustable. Toyota probably saved money by making it fixed.
Old Jul 2, 2009 | 02:41 PM
  #28
I guess so thanks for the help
heres the truck,
Old Jul 2, 2009 | 09:04 PM
  #29
Stuwy123's Avatar
Wow, your truck is so clean! So that's what my truck looks like with no rust.
Old Jul 3, 2009 | 05:49 PM
  #30
Thanks man i keep it pretty clean lol except when I get it muddy i keep it that way for awhile
icentropy
Sep 16, 2020 02:47 PM
mussy01
Dec 13, 2016 08:20 PM
Sep 4, 2015 09:27 AM
bobpat
Aug 1, 2015 09:25 PM
Sr5crawler
Jul 31, 2015 12:32 PM
