Weird squeal at startup..
Old Jan 12, 2009 | 11:23 PM
intelplatoon's Avatar
i just changed all my belts on my 93 runner, and it squeals at startup. I wasnt sure if one was to tight or to loose........everyone on here keeps saying to loose, so i'll just tighten up the loosest belt and see what happens???
Old Jan 13, 2009 | 04:15 AM
874runnersr5's Avatar
yeah, put your finger on the belts and push down, see how much "flex" is has.
Old Jan 13, 2009 | 04:27 AM
bigt's Avatar
knew it was that my runners did that b4
Old Jan 13, 2009 | 04:35 AM
ah i realized why i gave uplast time when i was putting everything back on, i found a much easier way.. Use the other side of a open ended wrench and get a ratched, pull with the wrench and tighten at the same time. very easy lol.
Old Jan 13, 2009 | 01:52 PM
  #25
Cyberman's Avatar
The WD40 trick isn't to stop the squeal forever, it is to let you know which belt needs tightened.
Old Feb 26, 2021 | 09:28 PM
  #26
tennis.daddy's Avatar
Talking
Originally Posted by 874runnersr5
fixed it!
so it was the alternator belt thing, i didnt think it was that loose but i tighten'd it up pretty good and started her and no noise!
yaya..
gave my ubolts for the rear leafs and everything else a good shot of pb buster to.
I had the exact same problem on my 89 Pickup. There would only be a squeal when the car started in the morning, or if it had not been run. It turns out it was loose drive belt, like you mentioned. I used a ratchet to loosen the pivot bolt on the underside of the alternator. Loosened it just barely so it could wiggle, then used a piece of wood and hammer to nudge the alternator and create tension. After acouple of tries it ended up working perfectly.
No more weird embarrassing looks!
Old Feb 27, 2021 | 04:02 AM
  #27
87-4runner's Avatar
Yup, now he only gets weird, embarrassing looks for responding to a 12 year old thread.
welcome to yotatech
Just messing with ya, glad your here.
rubronthroad
Nov 14, 2015 08:47 AM
Reno_eNVy
May 30, 2011 02:02 PM
pat24
Jun 26, 2007 07:11 AM
joeylead
Mar 12, 2007 04:29 PM
Mad Chemist
7
Jul 31, 2004 07:22 AM
